Using two-stage least squares
Posted: Fri Jul 03, 2015 12:57 pm
by Georgie
Hey guys,
I have a regression equation in which the unemployment rate is the dependent variable and the independent variables are the oil price, exchange rate, export and two time dummy's. I'm required to check out if the unemployment rate does not have a causal effect on the dependent variables because reverse causality is not allowed. Unfortunately I have no knowledge with Two-Stage Least Squares. What's a proper instrument variable? I was thinking on employed and unemployed people.
Re: Using two-stage least squares
Posted: Fri Jul 03, 2015 3:08 pm
by startz
Hey guys,
This is a little confusing as you say that the unemployment rate is the dependent variable. Assuming you meant no effect on the independent variables, the answer is no. You need to find instruments that are correlated with the RHS variables and not correlated with the error term. Employed and Unemployed people are certainly correlated with the error term.
Posted: Sat Jul 04, 2015 3:07 am
by Georgie
Hey guys,
I'm sorry, let me rephrase it. I did a LS-regression to check what effect the independent variables had on the dependent variable (unemployment rate). I also did a Granger-causality test to see if oil price (the focus of my regression) had a causal effect on unemployment rate and it did. The Granger-test also showed that unemployment rate has no causal effect on oil price, so it's one-directional. But I was still required to do a two-stage least squares regression to check for reverse causality. My supervisor told me to use lagged variables of all the independent variables, but I don't know what to do.
Posted: Sat Jul 04, 2015 6:50 am
by startz
Something like
tsls y c x1 x2 @ c x1(-1) x2(-1)
Posted: Sun Jul 05, 2015 4:10 am
by Georgie
Something like
So using the lagged variables in the 'Instrument Variables section' ?
Posted: Sun Jul 05, 2015 7:36 am
by startz
If your supervisor thinks these should be instruments, then that's where to put them.
Posted: Sun Jul 05, 2015 9:44 am
by Georgie
So how does two-stage least squares prove that there is no reverse causality from Y to the X-variables? I did what you said, using lagged variables as instrument variables and I got a negative R-squared value.
Posted: Sun Jul 05, 2015 10:01 am
by startz
There's nothing wrong with a negative R-squared.
Two-stage least squares--with valid instruments--does not prove anything about reverse causality. It "adjusts" for the effects of reverse causality. To see if reverse causality changes anything, consider using a Hausman test.
Posted: Sun Jul 05, 2015 10:24 am
by Georgie
Alright. Is it true that if the assumption of no serial correlation is met in OLS there's no need to do a 2SLS? Because at first I did an OLS-regression and it met all the assumptions like normal distribution, homoscedasticity, no serial correlation etc.
Posted: Sun Jul 05, 2015 11:01 am
by startz
No. Serial correlation has nothing to do with 2SLS.
Posted: Sun Jul 05, 2015 11:10 am
by Georgie
I want to thank you for the quick responses, really appreciate it.
I have a last question, so one image is with OLS and the other with 2SLS (using lagged variables of the independent variables as the instruments).
How do I interpret the difference between the results of OLS and 2SLS? A lower absolute R-squared with 2SLS indicates that 'adjustments' have been made for reverse causality?
Posted: Sun Jul 05, 2015 11:38 am
by startz
An idea of 2SLS is indeed that it adjusts for reverse causality, but the R^2 has nothing to do with it.
Look for "Hausman test" in the help files.
Posted: Sun Jul 05, 2015 12:28 pm
by Georgie
My supervisor specifically wants me to do a 2SLS-test but how do I interpret the difference between the OLS-results and 2SLS-results?
Posted: Sun Jul 05, 2015 12:58 pm
by startz
You're asking good questions. It might be time to go do a little background reading on 2SLS and instrumental variables to get a better idea of what's going on.
Posted: Sun Jul 05, 2015 1:17 pm
by Georgie
I'll go do that. Thanks for the quick responses.
