Unable to freeze RTADF output using command
Posted: Tue Jun 30, 2015 12:01 pm
by David Clark
I currently using the RTADF plug-in in order to pinpoint price bubbles. I use the following command (in the case for Wales) to attempt to estimate the model and freeze the results:
freeze(walesoutput) wales.rtadf(trend,info=aic,lag=3,model=3,sim,rep=1000,Trw,graph,print)
The model runs and output is produced, however the output is not frozen in the workfile. Attempting to recall the output using:
show walesoutput
returns an undefined error.
Can anyone shine any light on this? I am using Eviews 8.
Many thanks.
Re: Unable to freeze RTADF output using command
Posted: Tue Jun 30, 2015 12:16 pm
You cannot freeze add-ins.
Given you are writing code, you would be better off just modifying the rtadf add-in code so that it produces a table object. I'm not familiar with the add-in, but I would guess that it does actually produce the table you want and then deletes it at the end, so you can probably just remove the line that deletes.
Posted: Tue Jun 30, 2015 12:20 pm
by David Clark
HI Gareth,
Many thanks for your reply at this time in the evening.
I guessed as much but hoped there would be a simplier way; I'll have a try at amending the plug-in code and see if I have any luck.
Thanks again.
