Deleting a series from a unopened db crashes eviews
Posted: Thu Jun 25, 2015 6:59 am
Deleting a series from a unopened db crashes eviews:
Version 9 Jun 24 2015 build 32bit
Run this program in a instance of eviews:
Then, open another instance of Eviews and run this line:
This instance should crash.
If you open the database with dbopen before running the delete, no crash happens.
workfile u 1 100
series a1 = rnd
series a2 = rnd
db test
store test::a1
store test::a2Code: Select all
delete test::a*If you open the database with dbopen before running the delete, no crash happens.
