Hannan-Quinn
NicolasR
Hannan-Quinn
Postby NicolasR » Mon Jun 22, 2015 8:37 am
I'm programming a unit root test that requires uncorrelated residuals, for these i´m using information criteria to select the optimal lag length. The problem is with the command @hq, when i try to save the hq criteria in a scalar or in a control variable the following error appears "@HQ is an illegal or reserved name." (which does not appear with the other information criteria commands i.e @aic @schwarz). I`m using Eviews 9 64-bit version.
genr x=rnd equation e1.ls x c !hannan1=@hq 'first error scalar hannan2=@hq 'second error
However if I try to save it in a series it works.
series hannan3=@hq
Best regards.
Re: Hannan-Quinn
Postby EViews Gareth » Mon Jun 22, 2015 9:06 am
You're missing the equation name:
genr x=rnd equation e1.ls x c !hannan1=e1.@hq 'first error scalar hannan2=e1.@hq 'second error
