Parameter restrictions in Switching Regressions
Posted: Fri Jun 12, 2015 5:52 am
by Thomasms90
Is there any way to restrict coefficients in different regimes? I've only been able to restrict transition probabilities as it is.
In my case I'm estimating a simple 3 regime markov process with only the dependant variable and a constant (switchreg y c - i.e. no exogenous regressors or AR terms). I would like to identify an extreme regime with positive returns and high volatility (for instance restrict regime 3 to be positive and have higher variance than regime 1 and 2), but since I'm running a program with many loops, the regime may switch places. And it's very cumbersome to go through them one by one.
Re: Parameter restrictions in Switching Regressions
Posted: Fri Jun 12, 2015 8:46 am
Unfortunately not.
It's an interesting idea. I'd have to think about how one might implement the restriction, both in terms of interface, and internally.
Posted: Mon Jun 15, 2015 7:51 am
by Thomasms90
Alright. Was just in case there was a way to do it.
I'll manage without, no problem :-)
Posted: Tue Aug 23, 2016 2:18 pm
by FelipeP
I'm trying to do the same.
How did you work around this issue, Thomasms90?
Posted: Tue Aug 23, 2016 9:49 pm
by Thomasms90
I wrote a bunch of if's to compare the regimes and correctly classify them in a table, then used that table for lookups.
Posted: Wed Aug 24, 2016 9:40 am
by FelipeP
Thank you for such a prompt reply and your idea. I will do like you and use an IF.
I will use the IF to compare the coefficients, since I know a certain coefficient has to be higher in one regime than the other at all times.
