Moving sample method
Student15
Postby Student15 » Sat Jun 06, 2015 5:39 pm
Hi Guys
May you please help me with correctly declaring my sample objects in a rolling regression. I am trying to estimate a rolling regression with a moving window of 126 observations and a step size of 20.6. I am using daily data (irregular), so for example the observations from January 2004 to June 2004 are used to estimate the regression for June 2004, the observations from February to July 2004 will be used to estimate the regression for July 2004 and so forth till 2013.The errors I am getting are the division by zero errors but I am failing to correctly specify my sample objects. I have attached the work file. My code is as follows:
'run rolling regression ' set window size !window = 126 ' set step size !step = 20.6 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq1 'calculate number of rolls !nrolls = @round((!length-!window)/!step) 'matrix to store coefficient estimates matrix(9,!nrolls) coefmat ' where 9 is the number of coefficients matrix(9,!nrolls) tmat 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to @round((!length-!window)/!step) !j=!j+1 ' set sample to estimation period smpl @first+!i-1 @first+!i+!window-2 ' estimate equation sample s0 @first @first+!window-1 sample s1 @first+!step-1 @first+!window+!step-1 smpl @all ' declare coef vectors to use in ARCH likelihood coef(4) beta = 0 coef(3) alpha = 0 coef(1) dof = 0 coef(1) mu = 0 ' get starting values equation eq1.arch(1,1,ged,archm=sd,backcast=1) y c y(-1) eq1.makegarch garchm equation eq1.arch(1,1,ged,archm=sd,backcast=1) y c garchm*y(-1) y(-1) beta(1) = eq1.c(1) beta(2) = eq1.c(2) beta(3) = eq1.c(3) beta(4) = eq1.c(4) alpha(1) = eq1.c(5) alpha(2) = eq1.c(6) alpha(3) = eq1.c(7) dof(1) = eq1.c(8) mu(1) = eq1.@se^2 ' set presample values of expressions in logl series sig2 = mu(1) series resid = resid ' set up GARCH likelihood logl ll1 ll1.append @logl logl ll1.append @byeqn ll1.append resid = y - beta(2) - beta(1)*sig2 - beta(3)*sig2*y(-1)- beta(4)*y(-1) ll1.append sig2 = alpha(1)+ alpha(2)*resid(-1)^2 + alpha(3)*sig2(-1) ll1.append z = resid/@sqrt(sig2) ll1.append logl = log(@dged(z,dof(1))) - log(sig2)/2 ' declare coef vectors to use in ARCH likelihood coef(4) beta = 0 coef(1) thresh = 0 coef(3) alpha = 0 coef(1) dof = 0 coef(1) mu = 0 ' get starting values eq1.arch(1,1,thrsh=1,archm=sd,ged,backcast=1) y c y(-1) eq1.makegarch garchm eq1.arch(1,1,thrsh=1,archm=sd,ged,backcast=1) y c garchm*y(-1) y(-1) beta(1) = eq1.c(1) beta(2) = eq1.c(2) beta(3) = eq1.c(3) beta(4) = eq1.c(4) alpha(1) = eq1.c(5) alpha(2) = eq1.c(6) thresh(1) = eq1.c(7) alpha(3) = eq1.c(8) dof(1) = eq1.c(9) mu(1) = eq1.@se^2 ' set presample values of expressions in logl series sig2 = mu(1) series resid = resid ' set up GARCH likelihood logl ll1 ll1.append @logl logl ll1.append @byeqn ll1.append resid = y - beta(2) - beta(1)*sig2 - beta(3)*sig2*y(-1)- beta(4)*y(-1) ll1.append sig2 = alpha(1)+ alpha(2)*resid(-1)^2 + alpha(3)*sig2(-1) + thresh(1)*resid(-1)^2*(resid(-1)<0) ll1.append z = resid/@sqrt(sig2) ll1.append logl = log(@dged(z,dof(1))) - log(sig2)/2 ' estimate and display results smpl s1 ll1.ml(showopts, m=1000, c=1e-5) show ll1.output delete s0 s1 'store coefficients colplace(coefmat,ll1.@coefs,!j) colplace(tmat,ll1.@tstats,!j) next show coefmat show tmat
Thank you
daily returns.wf1
Company A
(69.86 KiB) Downloaded 253 times
