SUR and cross equation restrictions
Posted: Tue May 19, 2015 5:03 am
I have a system of equations that I am using and there are cross equation restrictions for the system (the same coefficients appear in each equation). I read that the SUR estimation method would be best as I have no IVs for the estimation, the Eviews (8) work file says cross equation restrictions can be used. However, I just read here:
http://forums.eviews.com/viewtopic.php?f=4&t=1862
That "The seemingly unrelated refers to the fact that you have a set of equations with no apparent cross-equation restrictions, but with non-zero off-diagonals"
So I am a little confused. Can we use a SUR estimation if there are cross equation restrictions? If not, would the appropriate approach be to use the GMM estimation?
Thanks!
Thanks!
