Overdispersion test
Nitzan04
Overdispersion test
Postby Nitzan04 » Mon May 18, 2015 8:19 am
equidispersion tests.docx
(24.36 KiB) Downloaded 584 times
I did both test that are mentioned in the manual Cameron and Trivedi and Wooldridge - is it reasonable that i got underdispersion at the first test and overdispersion at the last test?
Im really confused.
Re: Overdispersion test
Postby EViews Glenn » Mon May 18, 2015 11:17 am
For the first test, which variable is the original and which variable is the fitted?
Nitzan04
Postby Nitzan04 » Tue May 19, 2015 3:01 am
The first variable is the fit variable which i got by using the command: fit patentfittct . the second variable i got by "forecast".
Doesnt fit has the same meaning as forecast?!
It is really confusing because at the manual it written , and i quote :"first estimate the Poisson and obtain the fitted values of the dependent variable"
What should basically i need to do? can you guid my steps in Eviews so i can get a clear picture of the results of the dispersion.
Thank you in advance,
Nitzan.
Nitzan04
Postby Nitzan04 » Tue May 19, 2015 3:18 am
This is the result i just got after doing : a. astimate the variables by the Poisson-Count regression model, b. forecast and named the forecasted variable as " patentffinal", c. using the command :
equation testeq.ls (patent-patentffinal)^2-patent patentffinal^2.
Is it o.k?
CT TEST.docx
(22.02 KiB) Downloaded 548 times
Postby EViews Glenn » Tue May 19, 2015 1:07 pm
I haven't looked at the Cameron and Trivedi stuff in ages, so I haven't verified this, but from the description in the manual, your specification for the original test equation is incorrect.
The original test equation you estimated is
Your original equation was
equation testeq.ls (patentfittct - patentfct)^2-patentfittct patentfct^2.
when the manual suggests that you should have estimated
equation testeq.ls (patentfct - patentfittct)^2-patentfct patentfittct^2.
Your second attempt uses
which looks to be of the correct form.
