Generate monthly data from multiple annual data series
JanVinter
Postby JanVinter » Fri May 01, 2015 1:24 pm
I have a bunch of data series that have observations on an annual basis (lets call them a1, a2, a3, ...., aN)
I am looking to generate new series that have observations on a monthly basis by applying, say, the Denton method on the annual data series (utilizing an applicable indicator series) to create a high frequency series for every corresponding low frequency series (lets just call the new higher frequency series b1, b2, b3, ...., bN)
I know how to do this on a one-by-one basis by following the instructions laid out here: http://inceif-students.lefora.com/topic ... UOkSZPNKJ8
Unfortunately I have hundreds of series for which I need to undertake the same procedure, so a batch solution, if possible, would be naturally desirable.
Thanks in advance. I am using EViews 9.
Re: Generate monthly data from multiple annual data series
Postby EViews Gareth » Fri May 01, 2015 2:36 pm
Perform it on one series using the interface. Then look at the command capture window to find out what the command line version is. It should be something like:
copy(some options here) page\series page\series
Then write a simple program that loops through all the series and copies them one at a time:
pageselect annualpage %serieslist = @wlookup("*", "series") for %a {%serieslist} copy(some options here) annualpage\{%a} monthlypage\{%a} next
JanVinter
Postby JanVinter » Mon May 04, 2015 10:36 am
Perfect! Thank you Gareth. Your code has done the trick for me, albeit with some small modifications that I have written below
pageselect annualpage %serieslist = @wlookup("*", "series") for %a {%serieslist} pageselect monthlypage copy(some options here) annualpage\{%a} next
