Dear Eviews team
I use Eviews 8.1
As far as I have noticed objects contained in a spool loose their links to the respective original object and do not update automatically.
E.g., assume a series becoming an object in a spool. If the original series changes, the object in the spool remains unchanged.
Same applies to graphs, etc.
As such, the spool object is only of limited use.
Suggestion: assign objects (or at least some kind of objects) in a spool the option to be auto-updating
Best, mamo
Assign objects in a spool an auto-updating option
Re: Assign objects in a spool an auto-updating option
A spool can contain views of object that are computationally intensive to produce. The spool would have to remember all of the settings used to produce the views, too.
