Page 1 of 2
EXPORT REGRESSION TO EXCEL
Posted: Sun Apr 12, 2015 7:23 pm
by nano17440
I want to export all my regression tables to excel.
I tried the function write, WRITE(T=XLS,T,B2,s=data) e:\these\data\these.xls
However, it did not work.
Which function should i use to do it ?
Re: EXPORT REGRESSION TO EXCEL
Posted: Sun Apr 12, 2015 7:45 pm
What exactly do you mean by "all my regression tables"?
Posted: Mon Apr 13, 2015 9:53 am
by nano17440
I did 4 OLS regression on my diferent portfolios.
I want to export automaticaly the results from the OLS regression into excel in order to present my results on word afterwards.
Posted: Mon Apr 13, 2015 10:15 am
If you only have 4, I'd say just copy and paste.
Programmatically, if you want to get the exact same output as in each regression, then you'll have to freeze each equation into a table, then use table.save to save it to disk.
You might be better off looking at the eqtabs add-in which takes all the information from all the regressions in your workfile, summarises it into one table, and then saves that to an Excel file.
Posted: Mon Apr 13, 2015 10:25 am
by nano17440
In fact i have 4 regression for each model i run.
I am analyzing liquidity timing, market timing and volatility timing on different dates.
So i have around 30 regression in total.
If i do understand what you said, i should create a table for each regression in order to extract it ?
Posted: Mon Apr 13, 2015 10:28 am
If you want the entire regression output, yes.
Another way to do it would be to create a spool object, put all the equations into the spool, then save the spool to disk as an RTF file, and bypass Excel all together.
Posted: Mon Apr 13, 2015 10:52 am
by nano17440
How do i create a table to extract it afterwards on a excel file or compatible file ?
Posted: Mon Apr 13, 2015 11:14 am
Posted: Mon Apr 13, 2015 12:23 pm
by nano17440
I tried this without any success
'freeze[mytab] eq.stats
'tab1.save(t=xls) e:\these\data\essai1.xls
Posted: Wed Apr 15, 2015 9:06 am
by nano17440
What should i do ?
Posted: Wed Apr 15, 2015 9:10 am
You need parenthesis, not brackets.
Posted: Thu Apr 16, 2015 3:49 pm
by nano17440
It said tab1 is not defined
Posted: Thu Apr 16, 2015 4:16 pm
by nano17440
i did it wrong the first time, but it's still saying SAVE IS NOT A VALID VIEW
Posted: Thu Apr 16, 2015 4:40 pm
What is the exact command(s) you're using?
Posted: Thu Apr 16, 2015 4:53 pm
by nano17440
freeze gmm1
gmm1.save (t=xls) gmm
