GARCH-M with dummy variables
Posted: Mon Apr 06, 2015 2:36 pm
by ssccffv
I'm asked to perform a GARCH model of excess return of sp500 ranging from 2003M01 to 2013M12.
I got my ARMA model with 2 dummy variables. The independent variables are: dum01 dum02 AR(1) MA(1) MA(2) MA(6). dum01=1 from 2003 to 2007. dum02=1 from 2008 to 2009.
But when I tried to estimate a GARCH(1,1)-M model adding variance in the mean equation, all fitted value after2004M01 were NA. I re-estimated the model without dummy variables and everything seemed fine. Is there any difference between with and without dummy variables when performing a GARCH model ?
Besides, could anyone tell me whether the information table below the equations indicates the information of the mean equation or the variance equation in a ARCH/GARCH output window?
Thank you very much for any help.
Re: GARCH-M with dummy variables
Posted: Mon Apr 06, 2015 3:03 pm
We'd need to see the workfile.
The summary statistics are for the mean equation.
Posted: Tue Apr 07, 2015 3:40 am
by ssccffv
Hi Gareth,
Here is my workfile. https://www.dropbox.com/s/u2p9qkuxulavf ... 4.wf1?dl=0 The problem is in the equation "variance_in_mean".
Thanks a lot.
Posted: Tue Apr 07, 2015 4:07 am
What did you do that resulted in NA fitted values?
Posted: Tue Apr 07, 2015 4:17 am
by ssccffv
I went to Quick-Estimate Equation, then selected ARCH method. Line in the mean equation window was "ex_rt c dum01 dum02 AR(1) MA(1) MA(2) MA(6)". ARCH-M was "variance". For the variance section, model was GARCH/TGARCH. Order: ARCH 1, GARCH 1. Then just clicked "OK" I didn't change anything else.
Posted: Tue Apr 07, 2015 4:24 am
And where did you see the NAs?
Posted: Tue Apr 07, 2015 4:39 am
by ssccffv
When the equation came out, I checked the "Resids" and the figure was weird so I went to "Actual, Fitted, Residual Table" and found those NAs.
Posted: Tue Apr 07, 2015 5:10 am
What is the build date of your copy of EViews? You can view it under Help->About EViews.
Posted: Tue Apr 07, 2015 5:50 am
by ssccffv
The built date of the copy in my computer is 30 Jun 2011. It's Eviews 7.2. I also tried Eviews 8 in a computer in the school computer lab and it gave the same NAs. But I can't get the built date of that copy right now.
Posted: Tue Apr 07, 2015 6:00 am
You should update your copy to the latest version.
When I take the steps you take, I receive perfectly normal looking results.
Posted: Tue Apr 07, 2015 6:20 am
by ssccffv
OK, I'll try it again from the very start in a school's computer to see if I can get a normal result. Thank you very much, Gareth.
BTW, could you give me the workfile which you got a good result with? Thanks.
