Referencing Errors
diggetybo
Referencing Errors
Postby diggetybo » Thu Mar 19, 2015 11:41 pm
Hello
Question #1 is about Eviews 6 syntax for referencing errors from a regression in scalar computation.
The standard error of a regression
scalar sigma = @se
this works for the last regression run, say eq02, but what if I want to reference the standard error of the regression from an earlier equation, say eq01?
scalar sigma = @se@eq01
returns the error "non-numeric argument"
Question #2 is optional, just curious. Consider:
The standard error of coefficient i
Assuming the s.e. of the coefficient is i=1 then
scalar c_se = @stderrs(1)
the opperator
@stderrs
, from what I can tell, wasn't included in the command and programming reference's list of operators, or in user guide I or II, is it somewhere else?
trubador
Did you use forum search?
Re: Referencing Errors
Postby trubador » Fri Mar 20, 2015 1:48 am
There are plenty of syntax examples in the manual as well as in the forum. Just look carefully:
scalar sigma = eq01.@se scalar c_se = eq01.@stderrs(1)
These ones are located under "Equation/data members".
