Hi, I'm running a two variable VAR with a LR (Blanchard Quah) restriction. I am running it with the second difference of log real GDP and the first difference of the savings rate; the restriction is that shocks to the savings rate have no long run impact on growth of GDP. So, I would expect the accumulated impulse response of Output to my savings shock to converge to zero.
I have put this into Eviews in Matrix form using the 'C' Matrix and setting the top right element to zero.
I would also like to get confidence bands around my impulse response functions...
Could someone explain to me how you can do this
Many thanks
SVAR confidence bands with LR restriction
Re: SVAR confidence bands with LR restriction
Could I get some help on the coding for this! Would be much appreciated
Unfortunately, EViews does not have any built-in procedures to do so. A bootstrap code can be written with some effort, but it will have a problem of generating asymmetric error bands. The proper approach would be MCMC, but again EViews currently does not have any built-in functions for that purpose. So you need to write a code from scratch. You can try doing so and come back to ask if you need any help during the process.
