Quantile Regresssion on Panel data
Posted: Mon Mar 09, 2015 11:33 pm
by Ashish Garg
I am not familiar with high level mathematics, i want to apply quantile regression on stacked panel data. option is available in eviews 8. i have applied the same on my data and calculated the results i have not sure results are valid or not as such no literature is available on quantile regression on panel data. please help me.
Re: Quantile Regresssion on Panel data
Posted: Tue Mar 10, 2015 7:26 am
The quantile regrssion in a panel structured workfile is simply pooled estimation. It takes no account of the panel structure of your data.
Posted: Tue Mar 10, 2015 10:28 pm
by Ashish Garg
Dear Sir
thanks for your answer. does it mean that it is not considering time factor and it is normal cross sectional regression. if is a cross sectional regression then can the result which i am calculating is valid.
Posted: Wed Mar 18, 2015 5:19 am
by Ashish Garg
Thanks for your answer. does it mean that it is not considering time factor and it is normal cross sectional regression. if is a cross sectional regression then can the result which i am calculating is valid.
Posted: Wed Mar 18, 2015 3:39 pm
It's a pooled. There is no account taken of the time or cross-section of a given observation.
Posted: Wed May 02, 2018 4:38 am
by olayenidynare
Good afternoon
Suppose I write the following code:
equation qpanel.qreg y x @expand(var01)
or
equation qpanel.qreg y x c @expand(var01,@dropfirst)
won't that be equivalent to panel with fixed effect?
I'm just curious about it.
