Reshaping data into panel data
Posted: Mon Mar 09, 2015 10:15 am
by lana
Have a problem with my data! The dates are stuck with the variables i mean for each cross section in row i have the variable and the date stack in the same column
I dant to get for each cross section the dates in row and the variables in column
How can i do this
Thank you
Re: Reshaping data into panel data
Posted: Mon Mar 09, 2015 10:27 am
This post is quite indecipherable.
Posted: Mon Mar 09, 2015 11:05 am
by lana
Sorry
i'll share my data as soon as possible. I don't have it on my phone
Thank you
Posted: Mon Mar 09, 2015 12:24 pm
by lana
hello
this is my data. what is in yellow is my cross sections and what is in yellow are my cross sections and what is in blue is the variables with dates that I want to separate
thank you
Posted: Mon Mar 09, 2015 12:28 pm
by lana
I forgot to mention that the data is in the "data" sheet and what I want to get is in sheet 2 named "result"
Posted: Mon Mar 09, 2015 1:14 pm
I still have no idea what you want.
Posted: Mon Mar 09, 2015 1:31 pm
For a particular cross-section, the OP has the data for the variable aadcrobs in 3 columns, one each for 2012, 2013, and 2014.
Posted: Mon Mar 09, 2015 1:34 pm
by lana
ok, can you please see the attached files "data1" is the initial file and what I want to have is "data2".
number index is the cross sections but as you can see in "data1" variable (ETTAR and others that you can't see on the capture) are gathered with the dates
Posted: Mon Mar 09, 2015 1:50 pm
Can you provide the files?
Posted: Mon Mar 09, 2015 2:04 pm
by lana
I hope it will help :(
Posted: Mon Mar 09, 2015 2:15 pm
wfopen data.xlsx d *_year* pagestack 2007 2008 2009 2010 2011 2012 2013 2014 rename d_th_eur_ dd_th_eur_ rename *_th_eur_ * pagestruct index_number @date(var01)
Posted: Mon Mar 09, 2015 2:17 pm
by lana
where should I put this? I import data to eviews first ?
Posted: Mon Mar 09, 2015 2:33 pm
You can copy each line into the command window one at a time.
Posted: Mon Mar 09, 2015 2:57 pm
by lana
I don't know what to tell you realy you've saved my live :cry: :cry: :cry:
thank you so much . I was looking for a solution for a week now
thank you for what you do for the others
