Real Time BVAR
cantagallo
Real Time BVAR
Postby cantagallo » Thu Mar 05, 2015 2:27 pm
Hi!
I'm running a real-time forecasting exercise with a BM model, using the AR as a benchmark. I'd like to expand the model adding a BVAR benchmark (Minnesota prior). I use Eviews7 and dowloaded the BVAR add-in but I don't know how to use it in a real-time context, in the programming code.
I copy what I've done for the AR (hoping that it's not too long): can someone please help me?
!vqtr=1 for !v = 1 to 75 step 3 !vmth = 1 !vn = !v for %0 {%paese} call load_Qdata for %m1 %m2 "uni" "back" smpl 2005q4-!spanq+!vqtr 2005q4-1+!vqtr !tolav = 0.05 !tolin = 0.05 ' for %7 yar ddar mar xar pyar pdar pmar pxar equation eq_{%7}_{%0}.stepls(method={%m1}, {%m2}, btol={!tolin}, ftol={!tolav}) dlog({%7}_{%0}) c @ _ dlog({%7}_{%0}(-1)) dlog({%7}_{%0}(-2)) dlog({%7}_{%0}(-3)) dlog({%7}_{%0}(-4)) eq_{%7}_{%0}.ls next next smpl 2005q4-1+!vqtr+1 2005q4-1+!vqtr+!horizonq bm_{%0}.solve rename bm_{%0} v{!vqtr}_{!vmth}_bm_{%0} smpl @first 2005q4-1+!vqtr+!horizonq for %2 yar mar xar pyar pmar pxar genr v{!vqtr}_{!vmth}_{%2}_{%0} = {%2}_{%0}_0 delete {%2}_{%0} {%2}_{%0}_0 next ' ' this part computes the second and third month of the term !vmth = !vmth + 1 while !vmth<=3 !vn = !vn+1 smpl @all for %0 {%paese} 'HERE SAME CODE AS IN THE 1st LOOP !vmth = !vmth+1 wend !vqtr = !vqtr + 1 !vn=!vn+1 smpl @all next
Re: Real Time BVAR
Postby EViews Gareth » Thu Mar 05, 2015 7:32 pm
You're going to have to provide more details on what you're trying to do.
cantagallo
Re: Real Time BVAR
Postby cantagallo » Fri Mar 06, 2015 8:44 am
I think you're right, sorry.
If possible, I just need the programming code for the BVAR, equivalent to the AR part:
Re: Real Time BVAR
Postby EViews Gareth » Fri Mar 06, 2015 8:54 am
Still not clear.
From that code snippet it looks like you're using the built in stepwise least squares routine to select an appropriate lag distribution on the dependent variable for a simple linear least squares model.
What does that have to do with BVARs?
cantagallo
Re: Real Time BVAR
Postby cantagallo » Fri Mar 06, 2015 12:46 pm
I apologise again. That's right: I'd like to write a BVAR for the 6 variables (but with Eviews7, where only the add-in exists!) in the same position of my real-time code. Is it clearer? Sorry for that.
Re: Real Time BVAR
Postby EViews Gareth » Fri Mar 06, 2015 12:49 pm
Which 6 variables?
cantagallo
Re: Real Time BVAR
Postby cantagallo » Fri Mar 06, 2015 1:42 pm
GDP Import Export GDP_deflator Import_deflator Export_deflator
for US China Italy
