LU Decompositions
CharlieEVIEWS
LU Decompositions
Postby CharlieEVIEWS » Thu Feb 26, 2015 1:59 pm
Here's an early version of an attempted LU decomposition (partial pivot method). It's not overly efficient but I will possibly modify it to also work for matrices where the leading diagonal isn't zero at some point soon, and post below.
!n=@rows(A) matrix L = @identity(!n) matrix P= @identity(!n) matrix U=A for !k=1 to !n-1 vector temp = @subextract(U,!k,!k,!n,!k) !pivot=@max(@abs(temp)) for !j = 1 to @rows(temp) if @abs(temp(!j))=!pivot then !ind=!j+!k-1 ' !j=!n+1 endif next d temp vector temp_k = @subextract(U,!k,!k,!k,!n) vector temp_ind = @subextract(U,!ind,!k,!ind,!n) matplace(U,temp_k,!ind,!k) matplace(U,temp_ind,!k,!k) d temp_k temp_ind vector temp_k = @subextract(L,!k,1,!k,!k-1) vector temp_ind = @subextract(L,!ind,1,!ind,!k-1) matplace(L, temp_k,!ind,1) matplace(L, temp_ind,!k,1) d temp_k temp_ind vector temp_k = @rowextract(P,!k) vector temp_ind = @rowextract(P,!ind) matplace(P,temp_k,!ind,1) matplace(P,temp_ind,!k,1) d temp_k temp_ind for !j= !k+1 to !n L(!j,!k)=U(!j,!k)/U(!k,!k) matplace(U,@subextract(U,!j,!k,!j,!n)-L(!j,!k)*@subextract(U,!k,!k,!k,!n),!j,!k) next next
