Ajusted equation sample
Posted: Tue Feb 17, 2015 8:51 am
by MOG
HI,
Is there a way to retrieve the adjusted sample used in an equation?
Regards
Martin
Re: Ajusted equation sample
Posted: Tue Feb 17, 2015 10:57 am
by EViews Glenn
As a string? Or just being able to set the sample?
Posted: Wed Feb 18, 2015 12:12 am
by MOG
As a string, after the equation has been estimated. The {Equation}.@smpl-command only gives you the sample you set, not the adjusted sample.
Regards
Martin
Posted: Wed Feb 18, 2015 12:18 am
by EViews Glenn
The only place the adjusted sample string is available is in the output view. Other than that, the best you can do is to generate the residuals, and use them to construct your own adjusted sample string.
Posted: Wed Feb 18, 2015 12:28 am
by MOG
Ok, thanks!
Regards
Martin
Posted: Wed Jan 06, 2016 5:58 am
by TELLA
What is the main reason for adjusted equation sample.
Posted: Wed Jan 06, 2016 8:55 am
Some observations could not be used (usually due to NAs resulting from log of negative numbers), so the sample had to be adjusted.
