State Space -Forcast
Posted: Fri Feb 06, 2015 9:40 pm
I am reading the Eviews 8 manual on State Space models (Chapter 19 in User Guide II). I have the following questions I hope you can help me. I thank you in adavnce.
1. In the State-Space forecasting part, on page 623, it says, when they are multiple equations for a signal varaible, Eviews can not create a forecast series using wildcard"*". My question is, is there a case that there are multiple equations for a signal variable? Could you give me an example? Will Eviews be able estimate a model like that? I just can not imagine such a case.
2. On the same page in the manual, the second last paragraph, it says that "For the one-step ahead and smoothed methods, this means that at the earliest, the forecast period will begin n-1 observations into the estimation sample". Why n-1? not n?
3. The last sentence in the same paragraph, "for other initialiaztion methods, forecast sample endpoint adjustment is not required", what does it mean? Do we ever need to adjust the endpoint?
4. On top of the page 613, Is the recursive coefficent in the model the same as constant? Since you can say sv2=sv2(-1)=sv2(-2)=..., Does it become the same as a constant? Is that right?
Thank you very much.
Hank
Hank
