Student Version
Posted: Wed Feb 04, 2015 6:53 am
by senrabb
Just enquiring about the capabilities of the student version of EViews and want to know the specific limitations of the product.
I need to run a logistic regression testing the effect of many independent variables using max likelihood estimation. Will this product have any limitations to running this model?
Thanks.
Re: Student Version
Posted: Wed Feb 04, 2015 8:52 am
Define "many".
Re: Student Version
Posted: Wed Feb 04, 2015 9:13 am
Re: Student Version
Posted: Wed Feb 04, 2015 9:31 am
by senrabb
I have around 10-12 independents although I need to test all permutations of variables to specify the 'best' model recursively for over 250 data points using a max of 5 variables and a min of 2.
Re: Student Version
Posted: Wed Feb 04, 2015 9:38 am
10-12 independents is not many. 10,000 to 12,000 is many :)
Testing all the permutations will be tricky in the student version simply because the student version does not support programming. You'll have to do it all one at a time via the point and click interface.
Re: Student Version
Posted: Wed Feb 04, 2015 9:40 am
The student version doesn't support programming. That's going to make it hard to do what you want.
Re: Student Version
Posted: Fri Feb 06, 2015 10:03 am
by senrabb
I have decided to just run one logit with 5 variables which has a pretty good McFadden stat and i have a question about running this logit recursively with a rolling window.
I have a 256 month data sample and am looking to run this model with a rolling window of 72 months to then test out of sample for 24 months recursively every month. I need to store the fitted values of the logit every month although the rolling regression add in doesn't allow me to. Do i have to write a program to store these? Is there anyway I can run this recursive model without programming as I have little experience at writing code?
Re: Student Version
Posted: Fri Feb 06, 2015 10:22 am
You will have to program. The programming forum has lots of examples. Again, though, you cannot use the student version for this.
Re: Student Version
Posted: Wed Feb 11, 2015 8:48 am
by senrabb
I am using the EViews demo. Will there be any limitations to running the recursive code? For example, I'm having immediate trouble loading certain workfiles I have saved onto the program window?
Re: Student Version
Posted: Wed Feb 11, 2015 8:57 am
You cannot run programs in the Student Version.
