Common AR(1) term to list of coefficients
Posted: Fri Jan 30, 2015 3:07 pm
by RheaMaria
Dear all,
I am estimating a fixed effects model and am wondering if inputting the common AR(1) term into my list of common coefficients will correct for first order autocorrelation within cross-sections or between cross-sections given that it is highly significant. I'm not sure how it works in Eviews.
Rhea
Re: Common AR(1) term to list of coefficients
Posted: Fri Jan 30, 2015 3:09 pm
If you have a panel workfile, AR(1) will work within cross-sections.
Posted: Fri Jan 30, 2015 3:34 pm
by RheaMaria
Thank you very much! So am I correct in saying that the interpretation is then that of a first order autoregressive fixed effects panel estimation?
Also could I ask - is this valid considering I have already used cluster-robust standard errors - clustered by cross-section? I have come to understand that using this estimation ensures robustness for within cluster heteroskedasticity and serial correlation so I'm not sure what to make of this common AR(1) term.
Posted: Fri Jan 30, 2015 6:20 pm
Using AR(1) corrects the coefficient estimates and standard errors for serial correlation. Clustering by cross-section fixes the standard errors for serial correlation, but does not affect the coefficient estimates.
Posted: Sat Jan 31, 2015 2:05 am
by RheaMaria
Thank you very much! Really appreciate the help!
Posted: Tue Aug 02, 2016 12:41 pm
by Hercules1
Hello e-views forum,
hope everybody is doing well. I would really appreciate some help.
While estimating a fixed effects model, if I choose as a coefficient covariance method--> White cross section, then it means that my standard errors are robust for heteroskedasticity and first order serial correlation?
Thank you very much in advance.
Posted: Wed Aug 03, 2016 7:47 am
by Hercules1
Hello again to everybody,
I am back with more information cause it is complicated for me and I need some help,
I have panel (balanced data) and I estimated a fixed effects model. I have 14 countries and 11 years.
When I estimate, the DW statistic is 1, hence suggesting that I have positive autocorrelation.
so,
1) If I suppose that the autocorrelation is within the country, e-views help suggests : "we may adopt the Arellano (1987) approach of computing White coefficient covariance estimates that are robust to arbitrary within cross-section residual correlation (clustering by cross-section). Select the Options page and choose White period as the coefficient covariance method."
However when I use it, I get the warning regarding the number of cross sections. So it is not good to use it right?
2) this may sound very starters question, but when talking about an AR(1), you mean to include in the regression a lagged dependent variable.? Is that correct?
In that case the DW stat increases to 1.30
3) If I would like also to control for heteroskedasticity, which method to use?
Thank you very much,
Hercules
