Daily series from Datastream
Posted: Wed Jan 28, 2015 2:38 pm
by vytama
Eviews 8 here. I use fetch command to get time series from Datastream. I noticed that if the time series are daily (like oil or other commodities) and I have monthly workfile, the download is an average of the month, not the end of the month value. I talked to Datastream and obviously they are saying that it's a setting in Eviews where the change can be made. Is this true? if it is, how can I change to the last value of the month instead of average? Thanks
Re: Daily series from Datastream
Posted: Wed Jan 28, 2015 2:59 pm
fetch(c=l)
Posted: Thu Jan 29, 2015 6:12 am
by vytama
Thank you for the suggestion but if I add options to the fetch command - I get an error: Database error: "invalid date or date incompatible with frequency".
I am trying to pull CRUDOIL series from Datastream (it's daily series and my frequency is monthly in the workfile). I tried using: fetch (c=c) CRUDOIL, also specifying the database: fetch (d=datastream, c=c) CRUDOIL. Both times I get the error mentioned above. Can you tell me what I am doing incorrectly? Thanks.
Posted: Thu Jan 29, 2015 6:23 am
You have a space
Posted: Thu Jan 29, 2015 9:23 am
by vytama
Thanks Gareth, it did this issue and it runs. I tried changing (c=c) to (c=d) and other options - it would still pull the same average values for the month. It does not seem to pick up the last value. Could it be Datastream issue?
Posted: Thu Jan 29, 2015 2:46 pm
by EViews Jason
c=d is a low to high frequency conversion method. You want to use the high to low frequency settings. Use
fetch(c=l) crudoil 'find last non-NA
or
fetch(c=nl) crudoil 'include NAs
Posted: Sat Jan 31, 2015 6:11 am
by vytama
Thank you, it works.
