variance inflation factor
Philippe Rous
Postby Philippe Rous » Wed Jan 28, 2015 1:25 am
Hi everybody !
Why don't we get the same thing for the (centered) variance inflation factor of a given coefficient
1/ when we use the ready to use VARINF instruction
2/ when we compute this (centered) variance inflation factor "by hand" according to the help content : "The centered VIF is the ratio of the variance of the coefficient estimate from the original equation divided by the variance from a coefficient estimate from an equation with only that regressor and a constant".
e.g. the following code :
create u 100 genr x2 = @runif(1,100) genr x3 = x2 + nrnd genr x4 = X2 + X3 + nrnd genr y = 1 + X2 + X3 + X4 + 100 * nrnd equation eq1.ls y c x2 x3 x4 equation eq2.ls y c x2 scalar vif2 = (eq1.@stderrs(2)^2) / (eq2.@stderrs(2)^2) eq1.varinf show vif2
Re: variance inflation factor
Postby EViews Gareth » Wed Jan 28, 2015 6:48 am
The manual isn't quite right in the description, since the calculations hold sigmasq constant between the two regressions. The centered VIF is actually the variance of the coefficient from the original regression, divided by sigmasq (from original regression) / inner_product(Xi - mean(xi)).
As an example, you can run the following program that calculates it manually:
create u 100 genr x2 = @runif(1,100) genr x3 = x2 + nrnd genr x4 = X2 + X3 + nrnd genr y = 1 + X2 + X3 + X4 + 100 * nrnd equation eq1.ls y c x2 x3 x4 equation eq2.ls y c x2 scalar vif2 = eq1.@coefcov(2,2) / (eq1.@se^2 / @inner(x2-@mean(X2))) eq1.varinf show vif2
Philippe Rous
Postby Philippe Rous » Wed Jan 28, 2015 10:44 am
all is clear now !!! Thanks a lot !
