FMOLS: troubles with dummy & negative R-squared
Posted: Tue Jan 27, 2015 1:23 pm
I'm having some troubles with an FMOLS regression, so I will be grateful if someone can help me.
I have an unbalanced panel with 29 countries from 1970-2011 (yearly series).
I want to interact one variable (top1) with the state of development of each country. I've tried two differents ways.
1) The way that I would like to do it.
1.1) I created a dummy (advanced) which equals 1 for advanced countries and 0 for emerging countries.
1.2) I created the variable top1_ad = top1*advanced
1.3) I run this regression, which is saved under the name "regression1":
ca saldo_fiscal dep_joven dep_mayor pib_relativo2 pnae cred_ban cred_oif top1 top1_ad
Method: FMOLS
Panel-Method: Grouped
Trend-specification: Constant
Additional-trends: None
1.4) I received the following error message: "Positive or non-negative argument to function expected".
2) The second-best way to do it.
2.1) Instead of creating a dummy, I used the gdp per capita variable (gdp).
2.2) I created the variable top1_gdp = top1*gdp
2.3) I run the same regression, which is saved with the name "regression2"
2.4) The regression seems to work, but the R-squared is negative: -484.6356
My two questions are:
1) Why I couldn't use the dummy variable?
2) What does the negative R-squared mean? Is the second regression ok or should I drop it?
Thanks a lot for your help.
Method: FMOLS
