eViews 6: Kendall tau-b
Posted: Mon Jan 26, 2015 12:19 pm
by cfbiehl
Hello all,
I was wondering how I can code 'Kendall tau-b' in eViews 6.
Another post had asked a similar question, but unfortunately didn't get any replies.
Any help would be greatly appreciated!
Best,
Chris
Re: eViews 6: Kendall tau-b
Posted: Mon Jan 26, 2015 1:02 pm
Could you be more specific?
Posted: Thu Feb 05, 2015 5:06 am
by cfbiehl
Sorry of course:
I would like to run a Kendall tau-b test between two data series.
However, I cannot find the command for this test anywhere in the eviews handbooks.
In the interface it is possible to run the test I just don't know how to call on it through coding.
Posted: Thu Feb 05, 2015 8:33 am
How are you doing it via the interface?
Posted: Fri Feb 06, 2015 9:00 am
by cfbiehl
In the interface (eViews 6) I select the two data series, then open them as group, then View, Covariance analysis, then change method to Kendall's tau, tick tau-b and ok.
Now I would like to do the same through programming.
Thank you,
Chris
Posted: Fri Feb 06, 2015 9:33 am
group mygroup myseries1 myseries2
show mygroup.cov taub
Posted: Sat Feb 07, 2015 1:33 am
by cfbiehl
Great, thank you!
Posted: Sat Feb 07, 2015 5:48 am
by cfbiehl
As a brief follow up questions:
How can I draw on the results of the test, i.e. in the same way I can retrieve the coefficient of a ls regression by using @coefs(regression)?
In the end I would like to create a matrix with the test statistic of a large number of data series, i.e.
S1 S2 S3
S1 1 0.2 0.1
S2 0.2 1 0.3
S3 0.1 0.3 1
Also I do not want to just save the 'show' output as I would like to run this in a loop to test a large number of series.
Thank you for your help so far. Any tips regarding this would be great!
Posted: Sat Feb 07, 2015 11:17 am
Posted: Sun Feb 08, 2015 9:02 am
by cfbiehl
Thank you Gareth that does exactly what I wanted!
