re: Programming tests and procedures for Chaos
christchild23
Postby christchild23 » Tue Jul 21, 2009 2:58 pm
Hello All,
I am doing research in Chaos theory, and I need to run some tests for chaos. I do not have the software with the built in capability of doing such complex tests, but I suspect that one could program the codes for these tests into Eviews. For chaos theory, the most important test is the calculating the largest positive Lyapunov exponent. I would like to know what is the procedure to write a code for this function into Eviews. Would be very grateful if anyone can provide some technical assistance. Thanks much. Eagerly awaiting response.
Christian
Re: re: Programming tests and procedures for Chaos
Postby EViews Gareth » Tue Jul 21, 2009 3:14 pm
If you're asking someone to write a program for you, it would at least be courteous to write down the formula you're trying to have programmed, or, at least, a link to it.
christchild23
Postby christchild23 » Tue Jul 21, 2009 4:02 pm
I'm sorry. Here is the formula for the Lyapunov Exponent:
λ = lim 1/t ln |Δx (X0, t)| / |Δx0|
t→∞
| Δx0|→0
Apologies for the crude notation. The zeros attached to the xs within the mod signs are supposed to be subscripts. You can also see the formula at the following link:
http://hypertextbook.com/chaos/43.shtml
Thank you for your response.
christchild23
Postby christchild23 » Mon Aug 10, 2009 6:50 pm
i see I'd be much better of reading a book and doing my own trouble shooting. What a helpful response yours was. ^_^ Thanks much!
