Hi everyone,
I would appreciate if you can explain to me how to compute the credibility interval (confidence interval) of a bayesain VAR. I am using Eviews8 and it give only the impulse responses without the credibility interval.
Thank you in advance,
Imen
Bayesian VAR credibility interval
Re: Bayesian VAR credibility interval
EViews does not include CIs for BVARs.
Thank you for the reply. Is there any way to compute them manually?
Could you please answer to my question? Thank you
I don't know.
While I haven't read the BVAR documentation carefully, I think that for at least some of the priors the posterior is normal. In this case the credible intervals are the usual mean plus or minus 1.96 standard errors.
Yes. It is true, the posterior distribution is normal because I am using Minessota priors. But How can I extract the standard errors?
Aren't the standard errors in parentheses as usual?
