Questions on EGARCH and IGARCH
Posted: Thu Jul 16, 2009 12:56 pm
Hi guys,
Could someone please help me with this? Thanks
Q1. This is what I got from IGARCH(1,1). Could you please tell me what I should do with this?
Dependent Variable: R_JPY
Method: ML - ARCH (Marquardt) - Student's t distribution
Sample (adjusted): 1/06/1999 1/05/2009
Included observations: 2511 after adjustments
Failure to improve Likelihood after 1 iteration
Unable to evaluate derivatives at current parameter values
Presample variance: backcast (parameter = 0.7)
GARCH = C(2)*RESID(-1)^2 + (1 - C(2))*GARCH(-1)
Variable Coefficient Std. Error z-Statistic Prob.
C -0.004247 NA NA NA
Variance Equation
RESID(-1)^2 1.225047 NA NA NA
GARCH(-1) -0.225047 NA NA NA
T-DIST. DOF 20.00000 NA NA NA
Mean dependent var -0.004247 S.D. dependent var 1.107039
Q2. This is EGARCH(1,1) with 1 asymmetric order. Does C(4) mean that there is no asymmetric effect in the series because the probability is large? Thanks
Dependent Variable: R_AUD
Convergence achieved after 11 iterations
LOG(GARCH) = C(2) + C(3)*ABS(RESID(-1)/@SQRT(GARCH(-1))) + C(4)
*RESID(-1)/@SQRT(GARCH(-1)) + C(5)*LOG(GARCH(-1))
C 0.001571 0.008254 0.190328 0.8491
Variance Equation
C(2) -0.118823 0.023749 -5.003375 0.0000
C(3) 0.121916 0.020764 5.871557 0.0000
C(4) 0.009624 0.010597 0.908150 0.3638
C(5) 0.982936 0.007291 134.8214 0.0000
T-DIST. DOF 6.788451 0.985961 6.885110 0.0000
R-squared -0.000050 Mean dependent var -0.001853
Adjusted R-squared -0.000050 S.D. dependent var 0.485064
S.E. of regression 0.485076 Akaike info criterion 1.228690
Sum squared resid 590.5993 Schwarz criterion 1.242617
Log likelihood -1536.621 Hannan-Quinn criter. 1.233745
Durbin-Watson stat 2.030252
Variance Equation
Variance Equation
