Data: RESID already exists and can not be overwritten in
vutaikt
Contact:
Postby vutaikt » Thu Dec 04, 2014 8:41 am
A number of months ago, I wrote a couple of programs. One of the program pulled some data from a number of sources, did some adjustments and saved it into a database, adjusting for a specific frequency. The second program pulled the data from this database and that where I completed some estimation and econometric work.
In the past, I never had an issue with saving or pulling data from the database. However now, when I go to save or pull data I get the following error message:
RESID already exists and can not be overwritten in (FILE PATH)
I'm wondering what the problem might be and how I can fix this. In the period between uses of the program, my workstation was updated to Windows 7 as well as re-installed copy of Eviews. Is there an option or something I need to adjust?
regard
vutai
Re: Data: RESID already exists and can not be overwritten in
Postby EViews Gareth » Thu Dec 04, 2014 9:06 am
Sounds like you're trying to fetch the resid series, which cannot be done. Without knowing more details it is hard to give further advice.
