Program Log
Posted: Tue Dec 02, 2014 9:41 am
by MOG
Is there a way to supress the Program Log so it is not the front window, or even better, a way to save (freeze) the Program log as an object within the workfile?
Regards
Martin
Re: Program Log
Posted: Tue Dec 02, 2014 11:43 am
by EViews Jason
Unfortunately not. This is a kludge but you could do the following:
1. create log window via a program
logmode all statusline hello
2. minimize it the log window by pressing the _ button at the top right of the window
3.Run your program
To answer the second part, at the end of your program you would have to save the log to a file and then append that file to a text object. For example
logsave output.txt textobject mytextobject mytextobject.append(file) output.txt
Re: Program Log
Posted: Tue Dec 02, 2014 3:18 pm
by MOG
OK, thanks!
Martin
Re: Program Log
Posted: Wed Dec 03, 2014 3:01 am
by MOG
Works like a charm,
But is there no way to close the Program Log?
Regards
Martin
Re: Program Log
Posted: Fri Dec 05, 2014 10:11 am
by EViews Jason
Unfortunately not
