How to save residual series
Posted: Tue Nov 18, 2014 4:17 pm
by jdollery
I need to run a multivariate regression for over 200 times on Eviews 7 and need to save the residual series into excel sheet each time for further undertaking RUNS test (I believe Eviews doesn't have RUNS test, am I right?). Could you please send me the codes that can save the residual series into excel sheet when I run a regression each time? as being a beginner in programming, I would be very grateful if you could help me.
Best regards,
Helen
Re: How to save residual series
Posted: Tue Nov 18, 2014 4:27 pm
Use equation.makeresid to make the residuals into a series, then use wfsave to save the series into an Excel file.
EViews doesn't have the Runs test built in, but it does have the more popular Kolmogorov–Smirnov test. The Runs test shouldn't be too hard to program in EViews either.
Posted: Tue Nov 18, 2014 5:30 pm
by jdollery
Dear Gareth
Many thanks for your prompt reply. As I need to run a number of regressions together, could I save different residual series at the same time to excel sheet? For example, I've tried writing the codes for running two equations together (please see below), but it did not work. Could you please help?
equation eq1
eq1.ls a1 c b1
eq1.makeresid1
equation eq2
eq2.ls a2 c b2
eq2.makeresid2
wfsave C:\Users\HUBS\Desktop\excelxml
Looking forward to your advice. Thanks very much.
Best regards,
Helen
Posted: Tue Nov 18, 2014 6:00 pm
What doesn't work?
Posted: Tue Nov 18, 2014 6:13 pm
by jdollery
Dear Gareth
I tried running the codes below to save two residual series into an excel sheet, but after running it, I didn't get an excel file on my desktop. There must be something wrong with my codes. Could you please give me your advice? Many thanks.
equation eq1
eq1.ls a1 c b1
eq1.makeresid
equation eq2
eq2.ls a2 c b2
eq2.makeresid
wfsave("type = excelxml") C:\Users\HUBS\Desktop
Posted: Tue Nov 18, 2014 8:07 pm
You have to provide a file name
Posted: Wed Nov 19, 2014 4:36 am
by jdollery
Thanks.
