Generating series of 1 step ahead forecasts from VAR model
Posted: Wed Oct 29, 2014 7:07 am
by Intern
Hello all,
Please forgive the simplicity of my question as I am new to Eviews.
I have a data set covering the period 1993q1 to 2006q4. I am trying to generate a series of 1 step ahead ex-post forecasts starting from 2000q1 to 2006q4 using a VAR model. The idea is to estimate a VAR model using the sample 1993q1 to 1999q4 and generate a forecast for 2000q1, then estimate another VAR model with the sample 1993q1 to 2000q1 and generate a forecast for 2000q2, etc., repeating this step until the final date in the data set, then storing the resulting forecasts in a series.
My initial thought was to run the following code to estimate all the VAR models:
for !i=0 to 24 smpl @first 1999q1+!i var var01!i.ls lgdp cci
where lgdp and cci are the endogenous variables in the VAR.
However, I get an error message saying that var!i is not a valid name.
Could anyone provide help how I can estimate many VAR models by using a loop command, or suggest a better way on how to tackle this problem?
Thank you.
Re: Generating series of 1 step ahead forecasts from VAR mod
Posted: Wed Oct 29, 2014 9:17 am
You need to add the lags to your VAR.
create q 1990 2020 series lgdp=nrnd series cci=nrnd for !i=0 to 24 smpl @first 1999q1+!i var var01!i.ls 1 2 lgdp cci next
Posted: Thu Oct 30, 2014 1:29 am
by Intern
Thank you for your quick reply!
I have successfully estimated the required VARs now, but I am having some trouble generating the forecasts needed and storing them in a series. So far my code looks like this:
for !i=0 to 24 smpl @first 1999q1+!i var var01!i.ls 1 1 lgdp cci 'VAR forecasts var01!i.makemodel(mod01!i) mod01!i.solve smpl 2000q1+!i 2000q1+!i next
However the resulting series for the forecasts of lgdp, lgdp_0, only includes the forecasted value for 2006q1, but all the other values in lgdp_0 are just the actual observations. It seems that running the loop to solve all the models keeps overwriting the lgdp_0 series for each !i and only includes the last forecasted value in the series. Any idea on how I can store the forecasts for each !i in a series, and not have them being overwritten in the loop?
Thank you!
**Update
I tried modifying the code to the following:
table fcast for !i=0 to 24 smpl @first 1999q1+!i var var01!i.ls 1 1 lgdp cci 'VAR forecasts var01!i.makemodel(mod01!i) mod01!i.solve smpl 2000q1+!i 2000q1+!i fcast(1+!i, 1)= @elem(lgdp_0, "2000q1+!i") next
with the intention of extracting the forecasts for each !i in the loop, and storing them in the table fcast before being overwritten.
However I get an error message saying that 2000q1+0 is an illegal date.
Posted: Thu Oct 30, 2014 7:59 am
I would imagine you want your smpl statement before the solve command.
But your specific problem is that the @elem command doesn't recognise the "2000q1+!i" syntax.
You'll have to do something like:
%date = @otod(@dtoo("2000q1")+!i) fcast(1+!i, 1)= @elem(lgdp_0, %date)
