Autocorrelation and inference
Posted: Sat Oct 11, 2014 8:47 am
I am writing a thesis and I simply want to check inference concerning my regressions. I have the following three questions:
1)
Some of the regressions exhibit autocorrelation, but since I only care about inference I wonder if I should try to fix any of the autocorrelation using first differences and ARMA models or not. If I will be fixing only some of these regressions (not all of them are autocorrelated) and I wish to compare one regressions's statistical significance of coefficients to those of another regression, won't it this be a case of comparing non-similar regressions (for example one of fisrt differences with another that has not been corrected in such a way) so I shouldn't try this at all (again I only care about inference)?
2)
Also, in the end if I indeed do not correct autocorrelation, I apply the following procedure to remove heteroscedasticity:
I check if a regression is heteroscedastic but not autoreggressive. If it only heteroscedastic, I apply the White correction for S.E.
If a regression is both heteroscedastic and autoreggressive, I apply the Newey-West correction for both.
If a regression is autoregressive but not heteroscedastic, I make no correction.
Is the above reasoning correct?
3)
I have variables with values that are way to large, so I thought to use logs (natural logarithms). The problem is that many of the values are negative. Does it make sense to first have the absolute values of the initial values, then log these only positive values and then multiply these loged values with the initial signs for each observations, so that in the end I keep the sign and have values loged?
I hope I am not non-senical about anything bera with me I'm only a student.
Thank you in advance for your concern.
1)
2)
3)
