how to create vectors?
Posted: Fri Oct 10, 2014 8:14 am
by aiza
Hi! I have recently started using Eviews7. One thing I am unable to understand are vectors. As my research paper says "vector of explanatory variables", I am unable to incorporate it into software. Kindly guide me to identify the right option to create vectors.
Thanking in Anticipation!
Re: how to create vectors?
Posted: Fri Oct 10, 2014 8:20 am
The simple answer to your question is:
Click on Object->New Object, then select Vector.
However, I suspect you don't really want to create a vector at all, but without knowing what you are trying to do, it is difficult to tell you how to do it.
Posted: Fri Oct 10, 2014 8:28 am
by aiza
I have tried that but I am unable to incorporate data when I chose vector as "New Object".
Posted: Fri Oct 10, 2014 8:32 am
What are you trying to do?
Posted: Fri Oct 10, 2014 8:34 am
by aiza
I am trying to create vectors of explanatory variables.
Posted: Fri Oct 10, 2014 8:51 am
You actually want to create series objects then.
I'm assuming that your data already lie in a file somewhere (such as an Excel file, or a Stata file). You're best off just opening that file in EViews (File->Open->Foreign Data).
You should also look through some of the introductory lessons on using EViews:
http://www.eviews.com/Learning/basics.html
http://www.eviews.com/Learning/workfiles.html
Posted: Fri Oct 10, 2014 8:57 am
by aiza
Thank you for your guidance. I am going to follow your instructions.
