VAR-GARCH
Posted: Wed Oct 01, 2014 1:09 pm
by mollydokora
Hi everybody,
I'm currently working on my thesis and I should estimate the temporal volatility transmission across the crude oil market and different stock market sectors . I have the time series for oil and stock market indices logged from 1995 to 2013. I have EVIEWS 8.
I would like to ask if there is a way to build a bivariate VAR(1)-GARCH(1,1) model on EVIEWS: seems that the best software is RATS, but I have no idea how to use it.
I am replicating a study by Arouri, Jouini and Khuong 2012 and have no idea how to program this model in eviews.
Does anybody have an idea?
Thank you so much!
Re: VAR-GARCH
Posted: Fri Dec 19, 2014 5:10 am
by bvguizar
Did you get a reply about this? I am trying to do the same thing but for ethanol market.
Re: VAR-GARCH
Posted: Fri Dec 19, 2014 6:30 am
by trubador
Re: VAR-GARCH
Posted: Tue Dec 30, 2014 8:28 am
by bvguizar
Dear Trubador,
How can you calculate spillover ratios using BEKK or DCC models?
Re: VAR-GARCH
Posted: Wed Dec 31, 2014 2:42 am
by trubador
Re: VAR-GARCH
Posted: Fri Jan 02, 2015 9:30 am
by bvguizar
Dear Trubador,
I went through the post you sent and I was wondering if the programming for spillover ratios can be done using three variables?
I have done the programming again but when I ran it I see many problems. Please find attached the program and the E-views file. Could you help me with this?
Re: VAR-GARCH
Posted: Mon Jan 05, 2015 1:23 am
by trubador
That code estimates a bivariate garch-in-mean model as the name suggests. You need to get rid of in-mean specifications and modify the rest of the code so as to represent a VAR-GARCH model. It may be tedious, but not difficult. Even if you establish the correct specification, you may still experience some convergence problems. In that case, please search the forum for similar discussions.
Re: VAR-GARCH
Posted: Mon Jan 05, 2015 5:49 am
by bvguizar
Dear Trubador,
I am new to programming. I'm not sure where to put a VAR-GARCH model in here?
However, I have checked other posts
http://forums.eviews.com/viewtopic.php? ... 964#p26964
http://forums.eviews.com/viewtopic.php?f=4&t=9476
I thought I have changed the bivariate model to put it in 3 variables. So, a mean equation is not needed in a VAR-GARCH model?
Could you help me please?
Re: VAR-GARCH
Posted: Mon Jan 05, 2015 7:00 am
by trubador
The issue here appears to be more demanding than your programming skills. Your task requires technical background regarding: i) Spillover effects, ii) VAR-GARCH models and iii) Maximum likelihood estimation.
You confuse "in-mean" concept with "mean equation". The first one refers to inclusion of conditional volatility in the mean equation. In your case, mean equations should look like a VAR(1) model and the MGARCH part should operate on the residuals from those equations. And since you are interested in spillover effects, diagonal specifications will not work for you.
Re: VAR-GARCH
Posted: Mon Jan 05, 2015 7:06 am
by bvguizar
I am sorry for the trouble, yes I do have issue with this since I just got started to familiarise in these GARCH models. I have calculated a VAR in Microfit and I am using the residuals of the VAR to calculate the spillover effects. I wasn't aware of the limitations using diagonal specifications. In theory I assumed that once you estimate the BEKK model, you calculate the conditional variance of steady state. In a BEKK model with 3 series, for example, you are estimating 6 equations (3 variances and 3 covariances). Then you assume that Ht=Ht-1 and episilon t-1=0 (you are in equilibrium). This is how you find h11, h22, h33, h12, h13, h23 of steady state (six equations & six unknowns). And finally you simulate a shock in one market that changes the conditional variance (of steady state) by 1% and see how this affects the variances in all markets over a period of time. Can this be done in Eviews?
Re: VAR-GARCH
Posted: Tue Jan 06, 2015 2:53 am
by trubador
It is doable, but you may need to put a lot more effort into it than you think.
