XY Line where first series is an alpha
Posted: Sat Sep 13, 2014 2:10 pm
Suppose you make a group where the first object is an alpha and the rest are numerical series. Then you make an XY line graph. What should happen?
What I was hoping for was that the graph would use the first series as labels. (It would certainly be nice if it did.) What seems to happen is that you get a blank graph. I'm not sure if that's a bug, the intended behavior, no behavior is defined
, or user error. Look at group02 in the attached.
- Clipboard01.png (7.06 KiB) Viewed 7093 times
Re: XY Line where first series is an alpha
Posted: Sat Sep 13, 2014 9:15 pm
Intended behavior. The alpha is a series full of NAs, which makes a boring graph
Posted: Sun Sep 14, 2014 8:01 am
So is there another way to achieve the intended behavior? Excel is willing to
- Experienced teacher salaries relative to starting.png (10.95 KiB) Viewed 7076 times
Posted: Sun Sep 14, 2014 3:43 pm
Define the expected behaviour.
Posted: Sun Sep 14, 2014 3:48 pm
Use the observation number for the x-axis, but label the x-axis using the first series rather than the observation number.
Posted: Mon Sep 15, 2014 8:15 am
With your group open, run this:
d(noerr) temp
d(noerr) tempgr
%spec = _this.@members
%drop = @word(%spec,1)
group temp {%spec}
temp.drop {%drop}
freeze(tempgr) temp.line
tempgr.setobslabel(series) {%drop}
_this.display tempgr
d temp tempgr
I created some data with the following and ran it:
create u 4
alpha label
smpl 1 1
label = "Starting"
series us = 100
series oecd=100
series canada = 100
series finland = 100
series korea=100
smpl 2 2
label = "10 years"
series us = 123
series oecd=140
series canada = 150
series finland = 122
series korea=150
smpl 3 3
label = "15 years"
series us = 136
series oecd=140
series canada = 155
series finland = 128
series korea=160
smpl 4 4
label = "maximum"
series us = 150
series oecd=140
series canada = 155
series finland = 140
series korea=275
smpl @all
group g label us oecd canada finland korea
show g
Posted: Mon Sep 15, 2014 10:06 am
Wow, really nice.
Is there a gui way to setobslabel to do this manually?
Posted: Mon Sep 15, 2014 10:20 am
Yep
Posted: Mon Sep 15, 2014 10:24 am
Oh. So is the trick to make a line graph ignoring the label series, and then stick in the labels???
Posted: Mon Sep 15, 2014 10:40 am
Right.
Posted: Mon Sep 15, 2014 11:57 am
Not in may case, but I can see where that could be an issue.
Posted: Mon Sep 15, 2014 11:58 am
[edit]I previously asked whether there were any repeats in the alpha series which Startz responded to, just as I saw the posted workfile. I then deleted my earlier post so that I could post the following (sorry about the confusion).
In this case, I think there's a better approach. You have one label per observation with no repeats so I think that what you really want to do is to use the alpha series to label observations. In such a setting, I believe that
pagestruct tenure
group group03 us oecd canada finland korea
group03.line
would seem to give you want you want.
Posted: Mon Sep 15, 2014 2:26 pm
Thanks Glenn. Gareth's setobslabel "trick" avoids having to restructure the page. Any advantages or disadvantages one way or the other?
Posted: Mon Sep 15, 2014 3:45 pm
If the alpha are truly obs identifiers, then it's probably better to restructure since everywhere you have obs labels, we'll use them (as in the spreadsheet view, etc.).
Posted: Mon Sep 15, 2014 4:05 pm
Got it.
