Automatically Generate Interaction and Quadratic Terms
Posted: Sun Aug 17, 2014 11:49 pm
by kruupy
Hi all,
I need to estimate an 11 variable translog function. Translog functions involve a sqaured term for each of the variables aswell as including all possible combinations of interaction terms. Can Eviews automatically generate these for me? - as is going to take me a long long time to write them out manually.
Cheers,
Andrew.
Re: Automatically Generate Interaction and Quadratic Terms
Posted: Mon Aug 18, 2014 5:14 am
by kruupy
I am now trying to get Eviews and Matlab to talk. So I can use Matlab code to create the estimations i need.
In Matlab I have a string variable defined as "regression" which equals 'read c d_male'. I then run the following Eview code:
xopen(type=m)
xrun "run d:\eviews.m"
xget regression
xclose
Eviews then gets the variable successfully from matlab, and stores it in an SVector. How do I now use this SVector to estimation the equation "read c d_male"?
Posted: Mon Aug 18, 2014 6:00 am
by kruupy
Ok ive got it to work now however, is there a max string length or something? - because when I run the regression it compains about missing parenthesis because it cuts the string down.....
Posted: Mon Aug 18, 2014 6:26 am
by kruupy
The answer is yes, once i cut the big string into smaller parts the OLS regression worked, cheers.
Posted: Mon Aug 18, 2014 7:19 am
Take a look at Options/General options/Series and Alphas/Alpha truncation and see if changing the value there helps.
Posted: Mon Aug 18, 2014 8:31 am
by EViews Steve
I've taken a look again at the EViews code that is used to talk to MATLAB and I don't think their is a limit to the size of a string that can be retrieved. There may be issues with retrieving a string that contains newline characters in it (\n) because of the ambiguity of how MATLAB returns matrices (a 2x2 matrix is returned using spaces and newline characters as column and row delimiters). Or perhaps MATLAB itself is limiting the max size...
