Importing Undated Panel Data
kruupy
Postby kruupy » Thu Aug 14, 2014 11:48 pm
Hi All,
I have some panel data consisting of 4500 students(STU_NO) from 200(SCH_NO) schools. How do I import this as two dimensional panel data in eviews? - I have tried to import it in many times, however I can only successfully import 1 dimensional using STU_NO as the index. For example I Would like the data to look like:
SCH_NO STU_NO VARIABLES.........
1 1
1 2
1 3
1 4
1 5
2 6
2 7
2 8
2 9
2 10
etc... for each of the 200 schools.
So I would like to run panel regression: Y_ij c X1_ij X2_ij where i = student number and j=school.
Cheers and Thankyou everyone for your help.
Cheers,
Andrew/
Re: Importing Undated Panel Data
Postby EViews Gareth » Fri Aug 15, 2014 8:11 am
Should be able to open the file in EViews, then use Proc->Restructure to structure it as an undated panel.
kruupy
Postby kruupy » Sun Aug 17, 2014 12:27 am
I now have the data imported so that STU_NO is the identifier for each observation. However I want to setup panel data where SCH_NO and STU_NO are identifiers (i think its called stacking in eviews?)
I would like to be able to run panel data regressions as the following:
at the moment I can only run this regression:
Y_i c X1_i X2_i where i = student number.
So my problem is that I cant setup panel data structure in my workspace with an identifier (SCH_NO) that is not a date.
Postby EViews Glenn » Sun Aug 17, 2014 12:05 pm
You can structure by both STU_NO and SCH_NO as the unstructured identifiers.
I must admit that I'm still a bit confused about the structure of your data and how you are going to use the panel identifiers. Are you going to have different coefficients for each student/school pair? Do students move between schools? Is there a time dimension once you've structured by student and school.
