Pooled and time series data in one model
I am running a model which has a mix of pooled data (dependent and one independent variables) and time series (two independent variables). I would like to use pooled data analysis instead of running a time series on each cross sectional unit/country. Is that allowed?
nishantvats12
Re: Pooled and time series data in one model
It depends on the length of the time taken under consideration. If it is like for 10 years or more it is advisable to go for time-panel econometric techniques.
Also, when going for a simple panel model, you may not restrict yourself to pooled model alone, you might want to go for Fixed and/or Random Effect Models to get a better outcome. The thought of which method to use depends on the objective(s) of a researcher and/or statistical methods like the restrictive f test and the Haussman test.
