Is there an easy way to get the estimation equation as a string? say I have an equation object that when you view it has
Estimation Equation
A = C(1)B + C(2)B(-1)
Is there a
string my_eq = ?
... to get "A = C(1)B + C(2)B(-1)"
Thanks,
Luke
Estimation equation in a string
Re: Estimation equation in a string
Do you want the actual values of the coefficients?
lukevancleve
I do not.
Unfortunately there isn't an easy way.
equation.@subst returns it with substituted coefficients (i.e. their values).
You can either freeze the representations view into a text object and pull off the line containing the expression you want:
That might be tricky, because it might not always be the 7th row of the svector.
Or you could build up the expression yourself, getting the names of the variables and the coefficients from equation.@varlist and equation.@coeflist
freeze(temp) equation.representations
temp.svector temp2
%exp = temp2(7)
