Is there any way to run a VAR model with ordinal variables in EViews?
In other words, a model in which 2 variables, for example, are continuous and the third is an ordinal variable (that can take, say, only integer values of 1 to 10).
Thanks!
Ordinal variables...
Re: Ordinal variables...
There is nothing to keep you from mixing continuous and ordinal variables in an EViews VAR. Whether you should or not is a different question.
I understand, thanks!
