Accessing Datastream
Posted: Wed Apr 23, 2014 9:20 am
by please_work
I am trying to create a working connection to Datastream.
I was able to register the database, but when I open it (get message at bottom that username/password are validated) and try to run a test query (Query-Select), I get the following error message "Database Error: unable to load Datastream Series Picker library."
When I select View -> Query -> and any of the three options there appears to be no data living behind any of the choices.
Do you have any suggestions? I am running EViews 8 (64-bit).
Re: Accessing Datastream
Posted: Wed Apr 23, 2014 10:12 am
by EViews Jason
You will need to contact Thomson Reuters and have them send you the DSSeriesPicker installer.
Posted: Fri Apr 25, 2014 9:29 am
by please_work
I was able to get the DSSeriesPicker downloaded, and did get a message saying it was successfully registered, but am still getting a "Database Error: unable to Datastream Series Picker library."
Any suggestions?
Posted: Fri Apr 25, 2014 1:38 pm
by EViews Jason
My apologies, I did not read your post carefully. Thomson does not a have 64 bit compatible version of Series Picker library.
My suggestion would be to install the 32 bit version of EViews 8 and then use the 32 bit version when attempting to use the Datastream interface. You can still fetch data using EViews 8 64 bit but only via the 'fetch' command. In other words, anytime you want to use the 'Query-Select' or 'Query-AppendSelect' button in the Datastream database window, you have to use EViews 8 32 bit.
I should note, both EViews 8 32 and 64 bit can coexist on the same machine and will not cause any conflicts. You therefore do not need to uninstall EViews 8 64 bit version.
Posted: Mon Apr 28, 2014 11:53 am
by please_work
Got it - glad to hear I can make it work - thanks for the help!
Posted: Wed Sep 21, 2016 5:50 am
by dagfinnrime
Since I have been struggling with this I post my successful attempt here:
0. You can find the zip-file here
https://drive.google.com/file/d/0B2n4Rk ... sp=sharing (I was struggling finding it at Thomson Reuters)
1. Unzip the file to the Datastream folder (In my case: C:\Program Files (x86)\datastream\datastream advance)
3. Open the cmd.exe using Admin-rights. In Windows, enter cmd.exe in "Start-menu | Search"; Right-click on cmd.exe (among alternatives for your search) and choose "Run as administrator"
4. Go to the Datastream folder. I wrote
cd C:\Program Files (x86)\datastream\datastream advance
5. Run reg-server:
The zip-file came with a REGISTER.bat-file. Running that didn't work for me even when I choose "Run as admin". I was guided by the following post at StackExchange:
http://stackoverflow.com/questions/5413 ... 0x80004005
Hope this is useful.
Dagfinn
