Page 7 of 9
Re: Basic Rolling Regression
Posted: Tue Dec 13, 2016 8:50 am
Change the line that does the simple regression to be the lines that do the rolling regression.
Posted: Wed Jan 25, 2017 2:47 am
by saadallah
Hello Gareth,
I have a basic question. I have 10 time series of firms stock return for each country (France, Belgium and UK). So in total i have 30 time series.
fr1 fr2 fr3....fr10 (fr1 is the time series stock return of firm 1 in France)
be1 be2 be3...be10
uk1 uk2 uk3...uk10
And i have 3 different market indices : France( Frmkt), Belgium(bemkt) and UK(ukmkt)
I would like to estimate a basic CAPM.
I know that i can the long way and write a code that way. (I'm wondering if you could have a simplier technique)
matrix(2,10) francecoefs matrix(2,10) becoefs matrix(2,10) ukcoefs for !i=1 to 10 equation eq1.ls fr{!i} c frmkt next colplace(francecoefs, eq1.@coefs,!i) for !i=1 to 10 equation eq2.ls be{!i} c bemkt next colplace(beecoefs, eq2.@coefs,!i) for !i=1 to 10 equation eq3.ls uk{!i} c ukmkt next colplace(ukcoefs, eq3.@coefs,!i)
Thank you !
Posted: Wed Mar 01, 2017 9:07 am
by saadallah
Is it possible to perform Bai-Perron test with one maximum break , store the breakdate and then estimate rolling regression on the periode before the break date and the period after the breakdate? And then compare their means?
I know it sounds complicated but maybe someone before has done it
Posted: Wed Mar 01, 2017 11:02 am
Yes it is possible (although why use the Bai-Perron if you only have one breakdate?).
Posted: Tue Mar 07, 2017 3:37 am
by saadallah
Hello Gareth,
Thank you for your help. Well i could use Chow test if i know my breakdate. But in my case, i don't know the break date.
What do you suggest as other structural break test?
Thank you!
Posted: Tue Mar 07, 2017 8:30 am
Quandt-Andrews
Posted: Wed Mar 08, 2017 2:38 am
by saadallah
Thank you Gareth
I guess that Quandt-Andrews test gives the same result as the bai-perron test when defining maximum breaks =1.
svector(230) annee equation eq for !i=1 to 230 equation eq.ls y{!i} c x freeze(mytab) eq.ubreak 15 %text=mytab(10,1) !dotpos=@instr(%text, "(") %obstext=@mid(%text, !dotpos+1) %obstext=@left(%obstext,@length(%obstext)-1) annee(!i)=%obstext d mytab next matrix(230,1) pvalue !rowcounter=1 equation eq for !i=1 to 230 equation eq.ls y{!i} c x freeze(mytab) eq.ubreak 15 pvalue(!rowcounter,1)= @val(mytab(10,4)) !rowcounter=!rowcounter +1 d mytab next
Here's my code for those who are interested
Posted: Wed Mar 08, 2017 4:15 pm
by saadallah
Hello again,
I'd really appreciate any advice.
So, i have 230 series y: y1, y2, y3...y230. I want to estimate the equation ls y{!i} c x. (each of y on a constant and a serie x)
Then i want to estimate a break date using Quandt Andrews test and store the break date of this test.
After having the break date, i want to estimate rolling regression: ls y c x on each sub-period (period before the break date and after the break date) to compute the mean of the coefficient of x for each subperiod and check if they are statistically different.
I was thinking about writing the code this way.
Any help is appreciated thank you
equation eq for !k=1 to 230 equation eq.ls y{!k} c x freeze(mytab) eq.ubreak 15 %text=mytab(10,1) !dotpos=@instr(%text, "(") %obstext=@mid(%text, !dotpos+1) %obstext=@left(%obstext,@length(%obstext)-1) %obstext d mytab statusline rolling series y{!k} !window = 250 !step = 1 !length = @obsrange equation eq{!k} !nrolls = @round ((!length-!window)/!step) !rowcounter = 1 !j= 0 for !i = 1 to %obstext '!length - !window +1-!step step !step !j = !j+1 smpl @first+!i-1 @first+!i+ !window - 2 eq{!k}.ls y{!k} c x next for !t = %obstext to !length - !window +1-!step step !step !j = !j+1 smpl @first+!t-1 @first+!t+ !window - 2 eq{!k}.ls y{!k} c x next next
Posted: Thu Mar 16, 2017 10:43 am
by Econoforecast
For anyone still looking for a code that does a 1-period ahead recursive regression forecast (expanding window), I put together something from posts all over this forum. Most of the credits for these codes go to Esther and Gareth.
Try the code below. Note that I left out the coefficient matrix.
'create some data create u 100 series y=nrnd series x1=nrnd series x2=nrnd series z=nrnd 'run rolling regression ' set window size !window = 20 ' set step size !step = 1 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq1 'calculate number of rolls !nrolls = @floor((!length-!window)/!step) 'series to store forecast estimates series fcast '*EDITED: catching start and end points %start = "@first" '@otod(@ifirst(ser)) %end = "@last" '@otod(@ilast(ser)) 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j=!j+1 ' set sample for estimation period %first = @otod(@dtoo(%start)) %last = @otod(@dtoo(%start)+!i+!window-2) smpl {%first} {%last} ' estimate equation - where the equation is y =c(1) + c(2)*x1 +c(3)*x2 eq1.ls y c x1 x2 ' 1-period-ahead forecast %1pers = @otod(@dtoo(%start)+!i+!window-1) 'start point %1pere = @otod(@dtoo(%start)+!i+!window-1) 'end point '*EDITED if @dtoo(%end) < @dtoo(%1pere) then 'check whether the forecast end point is greater than the workfile end point exitloop endif ' set smpl for forecasting period smpl {%1pers} {%1pere} ' forecast with command *forecast* (see also *fit*) eq1.forecast(f=na) yf ' set sampl to obtain the 4th period observation smpl {%1pere} {%1pere} ' store forecasts fcast = yf next smpl @all show fcast.line d(noerr) yf
I have no real programming experience, so keep in mind that the code might not work 100% correctly. Any improvements are appreciated.
Thank you for posting this. Could anyone else (mod or user) who has used the above code for recursive forecasting OR has programming knowledge kindly confirm whether the above code works or has been written cleanly and should work?
I wish to use it, and modify it slightly and because I have no experience with programming, this could be convenient for me to pass through my data.
Posted: Sat Mar 18, 2017 6:47 am
by anne12
I am trying to run a rolling regression with forecast using real-time data that has a series for every month whereby only one regression is estimated per series for the window and when the window steps forward to the next month, the regression is estimated on the subsequent month’s series. I have a rolling regression with forecast program that works for a single dependent variable series but I need help expanding it so the regression moves from series to series for each rolling window. Thanks in advance.
Posted: Tue Mar 21, 2017 2:58 pm
by Charles_gre
Hi I am trying to make a rolling regression with fixed window size of 36 and step of 1. Finally, I want to store the sixteen coefficients of the equation (lp40000151nwer).
The code is:
equation lp40000151nwer
' set window size
!window = 36
' set step size
!step = 1
!length = @obsrange
!nrolls = @round((!length-!window)/!step)
'matrix to store coefficient estimates
matrix(16,!nrolls) coefmat ' where 3 is the number of coefficients
!j=0
for !i = 1 to @first+!i+!window-2
!j=!j+1
' set sample to estimation period
smpl @first+!i-1 @first+!i+!window-2
' estimate equation - where the equation is y=c(1) + c(2)*x1 + c(3)*x2
'store coefficients
colplace(coefmat,lp40000151nwer.@coefs,!j)
show coefmat
The problem is that the sample is not shifting by the step of one. How can I make the sample to shift by one step?
Thank you in advance.
Posted: Tue Mar 21, 2017 3:23 pm
by The Yoyo
Instead of
!j=!j+1
Maybe try:
Not sure if that solves it.
Posted: Wed Mar 22, 2017 1:10 pm
by Charles_gre
Thank you, but unfortunately, it is not working.
How can someone extract the point estimates? Is there a code like @coef to extract the point estimates?
Posted: Wed Mar 22, 2017 2:59 pm
by Charles_gre
The problem is that it keeps regressing, the whole sample all at once and not performing a rolling regression of a window size of 36 and a step of 1.
For example, I want to be able to regress
observations 1 to 36 get the coefficients of the regression.
Regress 2-37 and get the coefficients of the regression.
Regress observations 3-38 coefficients of the regression.
Ideally the outputs will be placed in a matrix
Until the end of the observations which is 106.
I require this for my thesis... it is very urgent and important.
If you could help me please, I will be grateful as I do not know anybody who can help me.
Posted: Wed Mar 22, 2017 3:13 pm
by The Yoyo
That sounds fairly simple. Not sure why it's not working. Try adjusting the following code (and ignore the forecasts it makes).
'create some data create u 100 series y=nrnd series x1=nrnd series x2=nrnd series z=nrnd 'run rolling regression ' set window size !window = 36 ' set step size !step = 1 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq1 'calculate number of rolls !nrolls = @floor((!length-!window)/!step) 'create matrix to store coefficients. We'll be running !nrolls regressions (!nrolls rows) for 3 coefficients, so 3 columns. matrix(!nrolls,3) coefmat 'series to store forecast estimates series fcast '*EDITED: catching start and end points %start = "@first" '@otod(@ifirst(ser)) %end = "@last" '@otod(@ilast(ser)) 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j=!j+1 ' set sample for estimation period %first = @otod(@dtoo(%start)+!i-1) %last = @otod(@dtoo(%start)+!i+!window-2) smpl {%first} {%last} ' estimate equation - where the equation is y =c(1) + c(2)*x1 +c(3)*x2 eq1.ls y c x1 x2 'store the coefficient vector of this estimation in a matrix-row (transposing it first, for conveniency) rowplace(coefmat,@transpose(eq1.@coefs),!i) ' 1-period-ahead forecast %1pers = @otod(@dtoo(%start)+!i+!window-1) 'start point %1pere = @otod(@dtoo(%start)+!i+!window-1) 'end point '*EDITED if @dtoo(%end) < @dtoo(%1pere) then 'check whether the forecast end point is greater than the workfile end point exitloop endif ' set smpl for forecasting period smpl {%1pers} {%1pere} ' forecast with command *forecast* (see also *fit*) eq1.forecast(f=na) yf ' set sampl to obtain the 4th period observation smpl {%1pere} {%1pere} ' store forecasts fcast = yf next smpl @all 'show fcast.line d(noerr) yf
