Page 7 of 11
Re: Fama-MacBeth regression
Posted: Tue Oct 21, 2014 10:40 am
by EViews Rebecca
Can you post the workfile you used?
Posted: Tue Oct 21, 2014 10:30 pm
by fan
Thanks for the reply. This is my workfile. I am looking forward to hearing from you.
Posted: Wed Oct 22, 2014 2:45 pm
by EViews Rebecca
Are you using "r*" to enter your portfolio returns in the add-in? In that case you will include the "resid" series, which you probably don't want to do. One solution is to rename the returns series to something that won't overlap with other series in your workfile.
Posted: Wed Oct 22, 2014 8:33 pm
by fan
thanks for the reply.
Posted: Tue Oct 28, 2014 1:15 pm
by fan
I am looking for help to implement following tests in the Fama-MacBeth regression. First, how can I include constant as a factor in the regression as many people do in their studies; second, how can I have the newey-west estimators from the time-series regressions and how can I test the joint significance of the loadings via SUR system; third, how can I have the t-statistics which are adjusted for errors-in-variables following Shanken (1992) and how can I have the adjusted R2 follows Jagannathan and Wang (1996) in the cross-sectional regressions. Thank you for your help
Posted: Tue Oct 28, 2014 1:19 pm
by vickyzao
First of all, make sure that you have EViews version 7.x or higher. Then, download the add-in and run the installation program (or simply unzip it). It will upload a documentation file into the related folder (C:\Users\...\Documents\EViews Addins\...), where you can find your answers.
1 point that i could not understand in file "fm_example". For specific rmkt is a factor, it had value during the period, so these values corresponded with pr11 or pr12 ,..? What about for each portofilios/asset return. X is a factor, in general, X has panel data (for example 25 porfolios, 588 observations), how can it be showed in a sheet? . Could anyone help me how to present a factor in a workfile? Could you please tell me soon?
Thank you so much for your help. :)
Posted: Tue Oct 28, 2014 2:23 pm
by EViews Rebecca
To answer your first question, look at equations 1 and 2 in the documentation. Your other questions are not covered by the add-in and you will need to do them yourself.
Posted: Tue Oct 28, 2014 2:24 pm
by EViews Rebecca
I don't understand what you're asking.
Posted: Wed Oct 29, 2014 2:54 am
by vickyzao
I would talk my case in details. I had 100 asset returns (in 36 months), monthly returns were estimated a below picture http://i1128.photobucket.com/albums/m48 ... yissue.png
To use addin in Eviews, my workfile inclueded:
+ rm* (representative rm1, rm2,..., rm100: monthly returns of stock 1, 2, ...., 100) in 36 months
+ factors: lnBM, lnMV, E_A, E_Y, 4 variables
Hope this picture help you understand me
I am waitng for your reply
Posted: Wed Oct 29, 2014 1:17 pm
by EViews Rebecca
The add-in does not handle factors that consist of multiple series.
Posted: Thu Oct 30, 2014 11:55 am
by fan
Can anyone help me understand why I am getting this error message: "MATRIX-VECTOR INDEX IS OUT OF RANGE IN "VECTOR RETIC=@TRANSPOSE@ROWEXTRACT(RM,J))" ? Many Thanks
Posted: Thu Oct 30, 2014 1:26 pm
by EViews Rebecca
Again, you need to post the workfile you're using.
Posted: Wed Nov 05, 2014 2:51 pm
by fan
This is my work file. I am trying estimate returns on pm1 to pm10 and pr11 to pr55. I am not sure why I am getting the error message. Thank you
Posted: Thu Nov 06, 2014 7:57 am
by EViews Rebecca
Works for me.
Posted: Mon Nov 17, 2014 2:49 am
by ecofin
hi,
how can use GLS or GMM instead OLS in this add-in?
1-suppose that pr* and rmkt are autocorrelation i can modifie the code to add ar(1) in the end of equation, but the problem i lose one observation (nobs=587) :(
equation {%subbetaeq}.ls {%subrets}(!i) c {%subfacs} ar(1)
how can generate error equations (E(i)=c(i)*Ei(-1)) for each equations (pr11 c rmkt, pr12 c rmkt,...etc), and use the c(i) to transform the observation to make the first step of regression of Fama-Macbeth and show all equation in the spool objects resolt and importe the c(i) in the vector, and show the transformed series pr* and rmkt.
same problem with the second step if i add ar(1) in the end of equation i lose 1 observation (n=24)
equation {%subcsavg}.ls avgrets c betag ar(1)
2-how can make Fama-Macbeth with GMM?
