Page 7 of 9
Re: Threshold Structural VAR
Posted: Sun Aug 20, 2017 12:47 am
by nasa
Here is my work file and I think based on the formula, the following is the result.Is that right,please?
The endogenous variables are: dgdp,dspending,dtax and the threshold variable and response variable is dgdp and the lag length for the VAR is 2.
Degrees of freedom=N-1.
b = 0.15*(2014q2-1960q1+1)+3-217
= 0.15*(218+1)+3-217
=-181.15
thsvar workfile.WF1
(151.16 KiB) Downloaded 1363 times
Best.
Posted: Sun Aug 20, 2017 2:04 am
by dakila
I don't think so. The degrees of freedom is just for adjustment of the sample size. It should not be big number. It may be between 0 to 5.
Posted: Sun Aug 20, 2017 2:14 am
by nasa
ok,
may be the formula is wrong or what is my wrong here is then?
plus can i get the impulses result in table form,please?
Best.
Posted: Fri Sep 08, 2017 12:26 am
by nasa
I think that the thsvar will be very useful add in for econometricians if it can include confidence intervals based on Monte Carlo simulations for the GIRFs. It could help them to better interpret the results.
Best
Posted: Mon Sep 11, 2017 3:40 pm
by dakila
thanks for the comment
Posted: Thu Oct 19, 2017 7:10 am
by EdgarM
Hello, thanks in advance for the add-in it was really usefull.
I have a question: When i estimate the TVAR with 3 dependent variables, i got 6 outputs instead of only one. I was replied that if i gather all the information in one matrix it was the same, but when i try to analize for example, serial correlation, the results are different for each regression.
How can i merge all of them in one test to unify the results? (or where can i study it, i've been searching in the web for a few days now without results).
Best regards,
Edgar
Posted: Fri Oct 20, 2017 5:16 pm
by dakila
Hello Edgar,
You can do it easily. For example, first estimate VAR model using the following code or the dialog box:
smpl 1960q1 1997q3 if d1=1 var var01.ls 1 4 d1gdp d1pgdp fyff cpbill1
Then use eviews VAR model test.
Posted: Tue Oct 24, 2017 1:09 pm
by EdgarM
Thank you very much Dakila!
Posted: Thu Nov 16, 2017 6:18 am
by banhbengconuong
Dear Dakila,
Thanks so much for making the add-in. I would like to ask whether we can have 2 thresholds for a variable?
Bests,
Posted: Thu Nov 16, 2017 7:31 am
by dakila
No
Posted: Wed Nov 22, 2017 6:59 pm
by bizhenyu1234
When I run this program, it shows error message "@ROW is not a member or procedure of SLAG".
Do you know how to deal with this problem?
Thank you very much!
Posted: Wed Nov 22, 2017 7:38 pm
Which version of EViews?
Posted: Wed Nov 22, 2017 7:47 pm
by bizhenyu1234
Eviews 7.2
Posted: Wed Nov 22, 2017 7:57 pm
You need a later version to run this add in
Posted: Wed Nov 22, 2017 10:43 pm
by bizhenyu1234
Now I can run this program.
