How to enter data into a panel workfile.
duynguyen88vn
Re: How to enter data into a panel workfile.
please help me! How to enter this data into a panel workfile??????
- sheetpanel.xls
- (108 KiB) Downloaded 1099 times
Could you describe it?
duynguyen88vn
i want to estimate : payout c grownth de cash......
used to random effect model, fix effect model
many thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You'll have to use a program to bring that in as a panel.
In EViews 8:
In EViews 8:
wfopen c:\temp\sheetpanel.xls byrow range="TANGIBILITY!a1:e101" @rename * *_tang
import c:\temp\sheetpanel.xls byrow range="PAYOUT!a1:e101" @rename * *_payout
import c:\temp\sheetpanel.xls byrow range="GROWTH!a1:e101" @rename * *_growth
import c:\temp\sheetpanel.xls byrow range="SIZE!a1:e101" @rename * *_size
import c:\temp\sheetpanel.xls byrow range="EPS!a1:e101" @rename * *_eps
import c:\temp\sheetpanel.xls byrow range="TAX!a1:e101" @rename * *_tax
import c:\temp\sheetpanel.xls byrow range="DE!a1:e101" @rename * *_de
import c:\temp\sheetpanel.xls byrow range="CASH!a1:e101" @rename * *_cash
pagestack(page=panel) ?_cash @ ?*
rename _* *
duynguyen88vn
hic. i used to run Eviews 6. can i run your wf by eviews 6?
can you send to me eviews file of this data?
You're probably best off just re-arranging the data in Excel.
duynguyen88vn
because very large amounts of data . I re-encoded it takes a lot of time!
Can i do it in Eviews 7?
duynguyen88vn
Can you send to me eviews of this sheetpanel!!!!!!!!!!!!!! thanks you very much!!!!!!!!!!!You're probably best off just re-arranging the data in Excel.
Hi Gareth,
I was trying to do the exercise by using the second data. I downloaded it and tried in version 7.1.
After doing the stacking in new page, I didn't get the id01 and id02! so I can't continue to the next step: unstacking..variable etc.
What seems to be the problem?
Thanks.
Dx
Thanks.
Dx
In EViews 7, ID01 is VAR01
Thanks.In EViews 7, ID01 is VAR01
I think it is different.
If you look at you posted workfile is says:
c
id01
id02
resid
state
variable
yr
What I got after new stacking:
c
resid
state
var01
variable
yr
there is no id01 and id02?
Hi Gareth,Use VAR01
attached is my data, formatted the same as your second example. I am new to eviews that is why I am trying to learn the basics..
I really want to know how to convert this excel format to eviews panel data..If possible, can you kindly give me step by step procedure to convert this to panel data? I may actually add some more variables on this later on.
I am using version 7.1
Thanks in advance.
Best.
Dx
Use "num?" as the stacking id in the page stacking part.
Use "firms var" as the unstacking id, and "var01" as the obs id in the unstacking part.
Hello Gareth,
I am using the second type of format on "Re: How to entre data into a panel workfile.". On Panel_STK workfile page, I type alpha var2..... in the command pane to create a new alpha series containing valid names. Once i stroke enter, a messages appears asking if I want to delete "variable" series. By tapping on "yes"tab, the "variable" series disappears but var2 series does not create. Any idea what I am doing wrongly? Thanks
