Page 4 of 4
Re: TVAR (Threshold VAR)
Posted: Fri Jul 12, 2013 7:19 am
by acinorev
What does the output that is received from the add-in represent
Posted: Fri Jul 12, 2013 9:06 am
Refer to the TsDyn documentation.
Posted: Mon Jul 29, 2013 6:26 am
by logos
I had the same error telling "evaluation stopped because of an error". The way I solved:
1) I opened R and, uninstalled tsdyn package and reloaded it. It tells that it loads the package but there is an error due to the lack of quadprod package.
2) I installed quadprod package.
2) As sweivE tells above, it might not read NA's. So I changed the sample.
It worked!
Posted: Mon Nov 11, 2013 8:39 am
by icprag
Dear All,
although using variables in their levels the TVAR addin works fine, when i use d(variable) it returns the message "evaluation stopped because of an error". Next i generated these series in first differences so as not to use the d symbol but the estimates in the reported table were all NA.
Could you please help me?
Posted: Sat Dec 07, 2013 6:37 pm
by tiantao920
hello ,I use the code of TVAR and i can get the result
but i want to get the graph of the impulse response
how can i get it
Posted: Thu Apr 07, 2016 5:00 pm
by dakila
Problem solved. You no longer need R to be installed. Please use the thsvar add-in.
