TVAR (Threshold VAR)
acinorev
Re: TVAR (Threshold VAR)
Postby acinorev » Fri Jul 12, 2013 7:19 am
What does the output that is received from the add-in represent
Postby EViews Gareth » Fri Jul 12, 2013 9:06 am
Refer to the TsDyn documentation.
logos
Postby logos » Mon Jul 29, 2013 6:26 am
I had the same error telling "evaluation stopped because of an error". The way I solved:
1) I opened R and, uninstalled tsdyn package and reloaded it. It tells that it loads the package but there is an error due to the lack of quadprod package.
2) I installed quadprod package.
2) As sweivE tells above, it might not read NA's. So I changed the sample.
It worked!
icprag
Postby icprag » Mon Nov 11, 2013 8:39 am
Dear All,
although using variables in their levels the TVAR addin works fine, when i use d(variable) it returns the message "evaluation stopped because of an error". Next i generated these series in first differences so as not to use the d symbol but the estimates in the reported table were all NA.
Could you please help me?
tiantao920
Postby tiantao920 » Sat Dec 07, 2013 6:37 pm
hello ,I use the code of TVAR and i can get the result
but i want to get the graph of the impulse response
how can i get it
dakila
Postby dakila » Thu Apr 07, 2016 5:00 pm
Problem solved. You no longer need R to be installed. Please use the thsvar add-in.
Return to “Add-in Support”
