Page 4 of 8
Re: Time varying SVAR
Posted: Tue Sep 20, 2016 3:34 am
by asif_1210
Hi, can anyone please help me as I'm consistently getting msg of 'illegal date vector'. I've created the date vector using the suggested command.
Posted: Tue Sep 20, 2016 3:14 pm
by dakila
if you are using the dialog interface (menu) do not use the command for date selection vector. Just put dates on the box. For example, enter 1975q1 1981q3 1996q1 on the box (date selection vector)
Posted: Thu Sep 22, 2016 3:54 am
by asif_1210
Hi, is there any method by which we can we can have data series of IRFs generated through TV SVAR?
Posted: Fri Sep 23, 2016 5:43 am
by nadybe
Hello Davaa,
I constantly have the "size don't match matrix function" error, what does it mean and how do i fix this issue?
Best regards
Posted: Wed Oct 26, 2016 10:16 pm
by adrangi
Hi. I'm new to add-ins. I tried to download tv_svar and open the prog in a workfile on eviews 9.5. Ended up with three files, tvsavr.prg, tvsavr.install.prg and tvsavr.ex.prg. Do I need to install before running the program? How do I install it? Any tips are appreciated. Thanks.
Posted: Wed Oct 26, 2016 10:27 pm
Posted: Thu Oct 27, 2016 11:13 am
by adrangi
Thanks very much. Best, BA
Posted: Thu Oct 27, 2016 7:30 pm
by adrangi
Hi. I read the pdf file for the TV-SVAR model. Does the "impulse variable" mean the endogenous variable that is being shocked? Don't we normally shock all endogenous variables and check the response by others in VARS? Any help is much appreciated. Thanks.
Posted: Fri Oct 28, 2016 1:48 am
by nadybe
The impulse variable is the variable that will affect all the other endogenous variables including itself, you can specify more than one impulse variable and see the impulses responses fonctions of the other endogenous variables as in the other Var model. If you need tips just message me i can help you.
Posted: Fri Oct 28, 2016 11:02 am
by adrangi
Hi. Thanks much. Clarifies it. Best, BA
Posted: Sat Nov 12, 2016 8:17 am
by marti
In April there was a question regarding saving the results as series, so that they can be exported. As you replied it would be possible with the release of version 2.0. I would like to ask if you are going to include the residuals as series as well despite the graph of the standard dev. When can we expect the new version?
Thanks,
Marti
Posted: Mon Nov 14, 2016 3:52 pm
by dakila
I will try to include the residuals. I hope it will be released in 2 weeks.
Posted: Thu Nov 17, 2016 10:55 am
by ali_Economist
Hi, I am trying to look at the impact of real rates on the unemployment and cpi, but is giving error Near Singular Matrix, I can,t log the series as these have negative values as well and also these are rates. Can you please help ?
Regards
Posted: Thu Nov 17, 2016 4:01 pm
by dakila
you have the multicollinearity problem. the correlation coefficient is almost minus one between real rates and cpi
Posted: Fri Nov 18, 2016 3:01 am
by ali_Economist
Yes, you are absolutely right, actually the CPI and unemployment are dependent variables and real rates are independent variables, so in simple regression it should not be the case of multicolinarity. Can you please suggest me how I can solve this issue in TVSVAR ? Thanks again for help.
Regards
Ali
